Ride height.. Has my bike been lowered? Measurement please?
Old Jan 8, 2020 | 06:35 PM
fitpays's Avatar
119.5 is stock for 2009+, which is where the difference in travel between generations of KLX comes from, I'm guessing. If you have an '06-'07 it's been lowered.
And I believe the forks are supposed to stick up 3mm above the triples, so at least the front was lowered.
It is an '09. After a couple hours of research, I found out that the 119.5 is stock. I plan to tighten the preload on the rear shock, and raise the front back to where it belongs. Then after some riding, I will determine whether I want to raise the rear. I am not particularly fond of how it looks with a rider on it. It squats a lot. I am 6' tall and weigh 200 pounds. I will see how it is with the front stock and rear stiff. I am planning to ride in some tight stuff where I am going to be putting my feet down a fair amount, blazing new trails. The ability to do this without dumping the bike, might be a little more important than the "cool look factor". Good to know it is a relatively easy mod though. Also good to know that there are probably plenty of pre-'09 owners that would trade me some 117's for mine lower dog bones.
Old Jan 8, 2020 | 06:51 PM
reinigef's Avatar
For what it's worth, I have a '14 which is identical to the '09. I have stock dog bones...the 119.5 I believe. I run my forks raised 10mm in the triple clamps for better turning and have not experienced head shake. I do have stiffer springs fore and aft however.
Old Jan 8, 2020 | 08:02 PM
durielk's Avatar
If you weigh 200#, your going to want a new spring in back.
Old Jan 8, 2020 | 10:50 PM
fitpays's Avatar
Damn it. Seriously?!?!?! Who makes an affordable aftermarket, and how big of a pain in the *** is it to change? I can't believe 200# is too much for it. Must be built for kids. My buddy that just bought the same bike is really out of luck. He's 260! I just looked at the Race Tech site. No idea which one I would need. I see them for sale on ebay a lot. Should I just assume that I need the most expensive one, since that is Murphy's law, and I would guess that the heavier the rider, the more expensive the spring?
Old Jan 9, 2020 | 10:51 AM
durielk's Avatar
I weight 175 and do no jumps, and ride at novice speed (compared to a pro) and use the stock spring. It is tightened up at the min recommended sag. I use stock rear shock and had my forks redone by a pro, racetech or the other service, I can't remember. You'll probably want to do the forks too! the bike is sprung for a 125# fast rider, it has the softest suspension I have ever had on any bike, IMO.
If you plan on just trail riding, no jumps, no high speed woops or dips.. stock may be ok.
If your a fast rider and into jumps, you need get info from them, cause I don't know.
clgdswr
Jun 15, 2009 01:40 AM
mooredan
Dec 12, 2007 04:07 PM
kawi boy
Sep 25, 2007 12:33 AM
rkutzner
Aug 28, 2007 10:28 PM
cwgoff
Mar 29, 2007 05:19 AM
