Fork tube height
Old Sep 24, 2007 | 10:15 PM
kawi boy's Avatar
Default Fork tube height
What' a good height to set the fork tube in the upper clamp?stock setting was 1/4 inch
Old Sep 25, 2007 | 12:33 AM
ZX1100F1's Avatar
Default RE: Fork tube height
The stock fork height is about 1/4" above the upper clamp.
You can slide the fork tubes down so they are even with the clamp for a little more height or raise them till they almost make contact with the bars (about 1/2" is all) to lower the front end, adjusting the fork height can make some fairly noticeable changes in the way the bike handles and if you go up too far you may have tire/fender clearance issues if you ride hard but your new Race Tech kit should all but completely eliminatethis from being a problem.
AZR
Dec 24, 2013 12:44 AM
cegusman
Jun 15, 2011 06:49 PM
albany551
Sep 10, 2009 03:43 AM
digitalmkc
Feb 5, 2009 01:07 AM
oldman
Sep 19, 2008 09:00 PM
