replacement stock sized dot tires
Old Sep 15, 2006 | 11:28 PM
scat's Avatar
Default RE: replacement stock sized dot tires
Bridgestone make the TW302 4.60-18 I installed one and so far very happy. And its D.O.T approved
I got the tire thru tiresunlimited.com
Old Sep 15, 2006 | 11:32 PM
jeepphamilee's Avatar
ORIGINAL: scat
That's my next tire too.
Old Sep 15, 2006 | 11:50 PM
dazjr's Avatar
I'm running the AC10 up front.
I've got almost 2000 miles on it now. It is a full knobby tire. It works good on the street, it just doesn't have very much feedback. The tire wear is a little weird. The middle ***** are barely worn. The next row ***** are more than half worn out and they are worn at a big angle. The next about 1/4 gone and the outside is not worn at all. I should be able to go another 1000 miles easy.
Old Sep 15, 2006 | 11:52 PM
FM_Thumper's Avatar
ORIGINAL: Iowaguy
Michelin AC10- anyone ever try this tire? It looks to be the one right now as it is dot and comes in stock sizes. I've never bought a Michelin anything tire. Any testimonies or opinions? Thanks
I was thinking of those too. They are M-Rated(Up to 87 mph) so that should be enough. Looking at the big gap between the treads, it looks like it may be a little spooky on asphalt however...
Old Sep 15, 2006 | 11:54 PM
FM_Thumper's Avatar
ORIGINAL: scat
Scat, how are they offroad on the KLX? I have used the Trail Wing series before on other bikes and they are great on-road and virtually last forever but it seems like the offroad performance is quite compormised?
Old Sep 16, 2006 | 12:03 AM
LordVngr's Avatar
ORIGINAL: Iowaguy
the reason I want to keep dot is because they're rated for higher speeds than non dot tires. I once took my KLX to near 90 mph on a long straight just to see if it would pull redline in top gear. these tires are rated for speeds near that i think. so no one has really answered my question- any dot besides the crappy stock in 100/100? pirelli, bridgestone, michelin, etc. no dunlops please.
90mph huh, Your a braver man then me. I wouldnt dream of pushing the little klx to those speeds. Hell I seldom push my sporty to those speeds. I guess if I wanted to go that fast or faster I would have bought a Sportbike. Good luck in your tire quest.
LV
Old Sep 16, 2006 | 12:50 AM
LKNY's Avatar
I'm with you.....it's not a street bike.
Old Sep 16, 2006 | 01:15 AM
scat's Avatar
ORIGINAL: FM_Thumper
ORIGINAL: scat
Very impressed with their single track performance i normally drop air pressure down a bit for the trails but the other day when duvallgold and myself went out i left them alone and had no problems. now this said this was in dry conditions so we will see what happen when we get some rain on those trails. I like there performance on the wet and dry pavement also wet gravel roads no problems. I just have no time on them in the mud quite yet so I will pass that info along once I have tried it.
lokeycmos
May 17, 2012 05:18 AM
scott3452
Sep 21, 2008 10:39 PM
2k1w=no$
Sep 6, 2008 02:17 PM
s197richie
Jun 2, 2008 06:47 PM
Marty
Nov 22, 2006 08:00 PM
