replacement stock sized dot tires
Old Sep 15, 2006 | 06:29 PM
bifflefan's Avatar
Default RE: replacement stock sized dot tires
YOUR BIG GUN DIDENT ELIMINATE YOUR NEED FOR TIRES? SORRY HAD TO DO IT.
Old Sep 15, 2006 | 07:10 PM
LordVngr's Avatar
Unless you live in a Inspection state I wouldnt worry to much about if its DOT approved or not. If a non inspection state I'd get what I wanted. Also just because it's not a Dunlop or Metzler or some other Major brand doesnt Necessarily mean it's a Sub par tire. My 2 cents dude.....
LV
Old Sep 15, 2006 | 07:20 PM
bryantjt's Avatar
Size wise they are measured about the same as a car tire. 100/100-18 is 100mm wide, the height is 100% of that per side + 18 inches so that should equate to (dividing 100 mm by 25.4mm/1inch) gives a 4 inch wide by 26 inch tall tire. Compare that to a 120/100-18 and you've got 4.7 inches wide by 27.5 inches tall. And even then you will have some variance due to the tread design, case in point K270 vs stock. Numerically the same size yet the 270 is a bit lower. The 110 you asked about would be 4.3 inches wide by 26.7 inches tall. But again it boils down to the tire in question and its tread pattern.
Old Sep 15, 2006 | 07:29 PM
Richt's Avatar
I run the trak masters but if your not worried about wear or $ the dunlop d739 rear and d736 front are about the best intermediate tire you can find.
Old Sep 15, 2006 | 07:49 PM
Marty's Avatar
You can order the replacment parts from Ron Ayers.
Front tire - 41009-0027 - $104.79
Rear tire - 41009-0028 - $133.58
Old Sep 15, 2006 | 09:47 PM
duvallgold's Avatar
ORIGINAL: Marty
Hard to believe they get that kind of money for the stock tires. I got a whopping 1500 miles on the stock rear. Could have maybe pushed it a little further but didn't want to try. I just put on an IRC GP-1 4.6-18 rear that I got from americanmototire.com for $61.14 including the shipping.
Old Sep 15, 2006 | 11:05 PM
ORIGINAL: Iowaguy
the reason I want to keep dot is because they're rated for higher speeds than non dot tires. I once took my KLX to near 90 mph on a long straight just to see if it would pull redline in top gear. these tires are rated for speeds near that i think. so no one has really answered my question- any dot besides the crappy stock in 100/100? pirelli, bridgestone, michelin, etc. no dunlops please.
Try www.americanmototire.com for browsing - click "dual sport" on the left for DOT tires, it will take you to a matrix of manufacturers. From there you can browse the various offerings. Careful with ordering from here, though - they will cancel your order with minimal notice (e-mail) if the item is out of stock. Also, no one answers the phone, communication is e-mail only.
I like www.rockymountainatv.com for tires and misc parts, but I like the above web site for browsing the available selection.
