Removing Counter Sprocket
Old Aug 19, 2013 | 06:22 PM
fenderworks2's Avatar
Default Removing Counter Sprocket
Wow,
i have removed counter sprockets before, but nothing like this on my 2006 KLX 250
Any Ideas? i cannot get the nut off the shaft. Pryed the washer back, but that nut just wont move. it will not get loose or tight, even tried to heat it up and it does nothing.
thanks
Old Aug 19, 2013 | 07:37 PM
darkmarc's Avatar
Careful with the heat. You might melt the seal behind the sprocket. Get somebody with an air impact wrench.
good luck
marc
Old Aug 19, 2013 | 08:07 PM
Brieninsac's Avatar
A common thread question, do a search and you'll find lots of suggestions.
Old Aug 19, 2013 | 08:44 PM
I went with a long, small diameter bar through the sprocket jammed up to the swing arms to lock the wheel then a big cheater bar. Regular threads - lefty loosey.
Old Aug 20, 2013 | 03:30 PM
donaldor's Avatar
Good excuse to buy that Craftsman 1/2" drive electric impact wrench you've always wanted.
Old Aug 20, 2013 | 03:44 PM
ahnh666's Avatar
$25 harbor freight electric impact wrench did the job...little impact and twist, and off light butter...
Old Aug 20, 2013 | 06:57 PM
Malves's Avatar
Yup, it's a b!tch to come out. I had to take the bike to a shop to use an impact gun before I messed up something else.
Old Aug 20, 2013 | 07:08 PM
zippets's Avatar
Exclamation +1+1+1+1
LISTEN TO THIS GUY ! ! !
you don't want mechanical tools that will screw up the fine thread
would you use an Impact wrench on your girl friend or wife ????
Treat your KLX like a fine women and she will treat you right for years to come
THINK TWICE before you try using Automotive machines to repair a delicate petunia like the KLX ! !!
Old Aug 20, 2013 | 10:57 PM
Thanks for the Help guys,
I may have to take it to the dealer............uuuugggghhhhh.
I have tried...big wrench, air impact gun, some heat, PB blaster,cheater bar, small socket, heck even a swiss army knife.....I am afraid I am going to break something.
i'm sweating, just telling the story
thanks
Old Aug 20, 2013 | 11:23 PM
250SM's Avatar
+2
Thats how i did it. easy.
