Removing Counter Sprocket
Old Aug 21, 2013 | 01:26 AM
zippets's Avatar
this is what i use 25" handle
1/2" Drive 25" Breaker Bar
Old Aug 21, 2013 | 11:02 AM
Malves's Avatar
Originally Posted by zippets
LISTEN TO THIS GUY ! ! !
you don't want mechanical tools that will screw up the fine thread
would you use an Impact wrench on your girl friend or wife ????
Treat your KLX like a fine women and she will treat you right for years to come
THINK TWICE before you try using Automotive machines to repair a delicate petunia like the KLX ! !!
OCD case. If you actually have a wife or girlfriend, I feel sorry for her.
Old Aug 21, 2013 | 10:36 PM
zippets's Avatar
<-----Female
have a OCD B/F
Old Aug 22, 2013 | 12:06 AM
2veedubs's Avatar
Originally Posted by darkmarc
Careful with the heat. You might melt the seal behind the sprocket. Get somebody with an air impact wrench.
good luck
marc
Heat is your friend. You would have to get it extremely hot to melt the seal. The engine itself gets really hot remember. Just apply heat to the nut, Kawasaki must use some weird thread lock compound as I had the same issue with my ZRX1200. With careful application of a propane torch my crappy 18v impact was able to remove the nut.
Old Aug 22, 2013 | 03:39 AM
Fuller_Malarkey's Avatar
Originally Posted by fenderworks2
Thanks for the Help guys,
I may have to take it to the dealer............uuuugggghhhhh.
I have tried...big wrench, air impact gun, some heat, PB blaster,cheater bar, small socket, heck even a swiss army knife.....I am afraid I am going to break something.
i'm sweating, just telling the story
thanks
Be careful with applying heat. There is more at risk than the seal, which, BTW, is designed to withstand about 285 degrees engine operating temperatures MAX. To break Red Loctite, you need a MINIMUM of 325 degrees. If the seal goes, you simply have to remove everything on the counter shaft again and replace the seal, once you find one, and hope it doesn't leak once you experiment with replacing a seal you've never replaced before. The "more at risk" is the tempering of the high carbon steel that composes the threads that holds this counter shaft sprocket on can be compromised. We then go from stubborn counter shaft nut to replacing counter shaft. Your bike, your call.
Before you pack up and go to the dealer, let's consider what the dealer will do that you can't. He's got breaker bars, extension pipes, and impact wrenches. He doesn't have a magic wand.
My suggestion: Haul the bike to a heavy truck / equipment repair shop that has high end impact tools and better regulated air pressure. I'm talkin' Caterpillar shop, Mack truck, Kenworth.....tire shop that does semi truck tires..truck lug nuts are spec'd to be torqued to 450-500 foot pounds, and it takes all that to get 'em back off. The mighty KLX counter shaft sprocket nuts gets torqued to a whoppin' 92.2 ft-lb. And those 22mm semi truck lug studs that get their nuts rattled on and off? Fine thread.
"you don't want mechanical tools that will screw up the fine thread"
We`ain't talkin' about beating a furry little bunny wabbit with a 2X4. It's a crude mechanical device with a jammed nut. There is no empirical evidence that a half inch breaker bar with a six to eight foot pipe applied by a 210 pound aggravated, angry, frustrated and likely slightly inebriated shade tree hack trumps the control-ability of an air regulated impact wrench. Nope.
My further suggestion would be to have the nut rattled off in NEUTRAL, not in gear. Run a rod through the sprocket holes above the swing arm. Sprockets are cheaper than transmission dogs IF there is a catastrophic episode....
I've had to cut the nut off, chase new threads, buy a new nut and get on with it. I've wore out countless cut off wheels on a dremel or air tool cutting counter shaft nuts off because beating on the side of an engine case with a chisel and BFH is bad ju-ju.
Remember: The dealer has no magic wand. He will experiment while you ain't lookin' over his shoulder. I have trouble trusting the outcome with my life. I agree, you've reached the point you need to reach out for outside assistance. Be realistic about the expectations. Heavy equipment shops rarely throw up their hands and say "guess we gotta take it to the dealer". They just buy better tools, like torque multipliers that enable them to break free things like stuck nuts without tearing things up. I am missing the correlation between this issue and a girlfriend, other than if you ignore a girlfriend, they'll eventually go away. Not the case with a froze counter shaft sprocket.
Old Aug 22, 2013 | 08:06 AM
250SM's Avatar
The moral of the story is to have the right tools for the job.
Old Aug 22, 2013 | 12:45 PM
djchan's Avatar
2 foot breaker bar, lots of PB Blaster, my 200 pounds, and a rubber mallet IIRC.
Only other C/S removal issues were on a KLR. Don't know what kind of gorillas Kawi employs but damn, they lock em down.
Old Aug 24, 2013 | 09:12 PM
RimBender's Avatar
swap 13 and 14 all the time and never had problems just snugging it up and 1/2 azz folding the locking washer. Doesn't need to be torque spec tight.
Old Aug 26, 2013 | 06:22 PM
fenderworks2's Avatar
Ok....finally got the counter sprocket off!!!!!!!
i wimped out....took it to the kawi dealer.....had it off in 30 seconds
As 250SM said " the moral of the story is to have the right tools"
thanks for all the comments
Old Aug 26, 2013 | 07:05 PM
cegusman's Avatar
Remember to not torque the crap out of it when putting it back on. Service manual only calls for 65 ft lbs. Any tighter and it is a bitch to get off.
Rosed
Sep 11, 2013 08:03 PM
AZR
Sep 9, 2013 11:20 AM
crazyapple92
Feb 12, 2013 06:17 PM
MJG
Sep 17, 2012 03:41 AM
drewski
Jun 30, 2007 02:50 PM
