red hot header... need help.
Old Dec 31, 2007 | 07:18 PM
pie4foou's Avatar
Default red hot header... need help.
i took out the smog crap, did the CC mod and only moved the jet up to a #120 (i know its not much but i have more on order 125 and 128 i think with the #40 pilot i belive and the needle and such..) This is my first bike so this is my first time doing all of this i'm sure its pretty simple answer... but why is my header getting red hot? i didnt really increase the air intake much, just added a k&n filter... and i havent changed the exhaust (havent drilled the baffels yet) so any advice would be great. (i'm not riding the bike untill i kinda figure out whats going on... i think its too lean, needs to be re jetted and should probably have the exhaust drilled out or replaced with an after market when i get the cash) ps... how does the air fule screw work? 1 turn out from your origional position or 2.5 out from all the way closed... i've heard two diffrent things.
Old Dec 31, 2007 | 07:34 PM
Bad Bear's Avatar
Default RE: red hot header... need help.
most of the 4 stroke engines of today if you see them run at night the header will glow red I bought a new Yam YFZ 450 and the first night I had it running and the header was GLOWING red...... Its normal because the bikes now days are set up very lean from the factory to meet EPA standards.....If you rejet you should be fine
Old Dec 31, 2007 | 07:36 PM
pie4foou's Avatar
my heart was kinda racing on that one... i thought i may have done some pretty good damage by not re jetting or something.... so I'm not going to like blow my engine if i go and ride it around??? maybe I'll put my foam filter back in for good measures
Old Dec 31, 2007 | 08:07 PM
Don't open up the airbox lid - keep it restricted with the stock snorkel until you can rejet with that 128. Fuel screw should be lightly seated, then backed out. 2 to 2.5 out is typical.
Old Dec 31, 2007 | 08:11 PM
Also, don't forget the needle - N1TC, w/clip and collar, clip on 3rd position is typical. Check the common part numbers thread for part numbers. Some folks use a spacer for the stock needle, but the N1TC w/clip allows for a broader range of adjustment.
Old Dec 31, 2007 | 08:19 PM
Do what nobrakes said BUT......Mine will glow red at night when maintaining 7.5K+ rpms ..... I think its just a hot SOB ...... been that way for a year now. lol
Old Dec 31, 2007 | 09:23 PM
pie4foou's Avatar
16009-1912--------Needle-Jet,N1TC
92143-1667--------Needle Collar (required for N1TC needle)
92037-1401--------Clamp, Needle Jet (Clip, required for N1TC needle)
92063-1069--------#125 Main Jet and/or
92063-1074--------#128 Main Jet
pilot jet #40
part #- 92064-1108
(thanks finger mullet, you suggested these parts in a thread a few weeks ago)
so anyway... there on the way. or so they say. last time i ordered something my card didnt go thru and he never ordered it, or called me back... said he had the wrong number... ugh. so its been like 3 weeks waiting for these parts.
ps... anyone wanna buy my K&N filter? its only a few weeks old...
Old Dec 31, 2007 | 11:48 PM
pie4foou's Avatar
my pipe is turning blueish... would drilling the exhaust help in the mean time? or just make it worse?
Old Jan 1, 2008 | 12:00 AM
It'll turn blue regardless. Makes it look cool.
Old Jan 1, 2008 | 12:50 AM
pie4foou's Avatar
right on... i just dont want to hurt my little precious baby now. i mean i dont mind throwin down in the mudd, but i cant be pushin it around town when all hell breaks loose because i didnt do my research (by research i mean picking all of your brains, heheh)
