Rear Sprocket
Old Nov 19, 2013 | 11:59 PM
RockabillSlapMatt's Avatar
Originally Posted by TNC
Mine "would" pull redline in 6th gear with my 13/47 and current engine setup, but I don't ever do it. Mine is an '06 "S" model with knobby tires, so I don't need to do whatever max speed is. I can see why an SF owner might want or need to. I cruise at a true 55 at about 7000 rpm as calibrated in a Trailtech Vapor instrument panel. I run a 110/100/18 rear tire. The bike is definitely not set up for interstate travel.
AHHHH!!!! 7k at 55mph! That much be pretty good on the trail! With my 351 13/39 gearing my first gear runs out at 14mph. top speed (redlining) is 90mph
Old Nov 20, 2013 | 12:32 AM
I wondered if it would be too low, but in Colorado in some off road conditions, the 14/47 was a hair too high. And not oddly, the 13/47 is pretty much like the KLX300 model's 14/50 stock gearing.
Old Dec 1, 2013 | 12:48 AM
GTackett's Avatar
Default 13/42
I currently have the stock 14/42, but 6th just won't wind out (FMF pipe, k&n filter, 125 main jet ???...according to the previous owner).
Thoughts on going to 13/42? Gearing down for the woods couldn't hurt, but wasn't sure how it would effect the top end on the highway.
Old Dec 1, 2013 | 01:50 AM
Pine Barrens's Avatar
I have 13/42. Though I do not ride on the road, did not notice any loss of top end.
Old Dec 1, 2013 | 01:58 AM
With the 250 you don't loose any top end, if anything you might gain a mph or two, but it'll be buzzing at 9k rpm
Old Dec 1, 2013 | 02:17 AM
GTackett's Avatar
9k in 6th gear? Doesn't a rev limiter kick in before then?
Old Dec 1, 2013 | 04:21 AM
rev limit is 10.5
Old Dec 1, 2013 | 01:16 PM
GTackett's Avatar
rev limit is 10.5
My 06 begins missing around 8k. I haven't been able to pin point exactly where it begins missing...and maybe its jetting??? Previous owner thinks he put in 125 main jet. Could a slightly larger main jet help high rev miss?
Old Dec 1, 2013 | 04:31 PM
I get a miss sometimes too around 8k, either it's too lean and its starving for fuel, or its too rich and it starts 8 stroking. Usually happens for me full throttle 8k rpm under load.
Old Dec 1, 2013 | 04:49 PM
SageGrouse8139's Avatar
Speaking only from my personal experience and not as a professional mechanic although I do play one on TV.... (OK I lied about that part) an engine missing at high rpm whether car or (4 stroke) bike engine is an ignition problem. As I say this has been my experience but I could believe it is getting starved of gas at high rpms due to jetting but it's just not something I have seen. Easy to put a new plug in it to see if that makes any difference. Plug wire shorting? I have a habit of being quick to blame electrical problems.
