Rear Sprocket
I have already changed my front sprocket to a 13 tooth and I am thinking about going up a few teeth on the rear from 42t to 47t. Can I use the same chain with the larger sprocket? Thanks.
I've run 13/14/15 front with rear/chain:
stock 42 / 106 tooth
49 / 110 tooth
45 / 108 tooth
You won't be able to use the 106.
If you get a new chain, buy a 110 or longer and get a chain cutter.
49 / 110 tooth
45 / 108 tooth
hey a quick question....
what do you top out at (mph) with a 13/47 setup?
I can get up to 130km/h: 80mp/h (indicated) (with shinko 244's) on my 14/39 setup. With the 13/39 set up I saw a top speed of about 124km/h....
Mine "would" pull redline in 6th gear with my 13/47 and current engine setup, but I don't ever do it. Mine is an '06 "S" model with knobby tires, so I don't need to do whatever max speed is. I can see why an SF owner might want or need to. I cruise at a true 55 at about 7000 rpm as calibrated in a Trailtech Vapor instrument panel. I run a 110/100/18 rear tire. The bike is definitely not set up for interstate travel.
No, haven't checked, but I need to make a correction on my rpm to speed. Late this afternoon I ran the bike while preparing for a trip to the Big Bend area. My rpm at 50 is 6000...60 is 7300...70 is 8800. I'll check on the chain in just a bit.
Looks like 110 links on mine.
