Rear brake lever position
Old 02-04-2007, 01:03 AM
Ziguy's Avatar
Default Rear brake lever position
When I sit normally on the bike, the position of the rear brake lever seems really too high. I have to lift my foot from the peg to apply rear brake. Do you have the same problem?
Old 02-04-2007, 02:46 AM
Default RE: Rear brake lever position
Na i have big feet, size 14, so my foot is big enough i just pivot it on the footpeg...
Old 02-04-2007, 03:41 AM
KLXer's Avatar
You can adjust the position to your liking.
Old 02-04-2007, 04:09 AM
ORIGINAL: KLXer
That's what I did - lowered it a bit otherwise I seemed to want to drag the brake when wearing my MX boots. It's much better now. If you do lower it, but sure and adjust your brake light switch activation point otherwise it might be on all the time.
Old 02-04-2007, 05:21 AM
EvildoerZX10R's Avatar
Good advise! I need to lower mine also. I have the same problem when wearing my MX boots. It is hard to shift with those things on too.
Old 02-04-2007, 04:38 PM
bryantjt's Avatar
Oh man I have the same problem, it wasn't bad when I just had hiking boots on but with 10" steel toe workboots (compromise for work comfort and some street protection) I have to take my foot off the peg to use the rear brake, especially if I'm standing up. So what did you guys do to lower the pedal? The one on my Yamaha Warrior atv had an adjustable stop point with a long turnbuckle on it but the only thing I could think of doing with the KLX setup is to screw in the plunger rod but I don't see much adjustment there so I left it alone.
Old 02-04-2007, 04:52 PM
ORIGINAL: bryantjt
The manual says it's non-adjustable, but it really is. You need to disconnect the clevis pin from the lever - cotter pin. Then loosen the nut above the clevis and then screw the clevis further up on the rod which connects it to the master cylinder to lower the pedal height. When the height is right, tighten it back up and reinsert the clevis pin. Don't forget to adjust the brake light actuator switch - there's an adjustment for that too. Otherwise, the brake light may be actuated after you lower the brake lever or be ultra-sensative.
Old 02-04-2007, 05:05 PM
bryantjt's Avatar
Ok thats what I thought I could do but not seeing any threaded shaft I didn't mess with it. Thanks!
Old 02-04-2007, 07:35 PM
mmatz's Avatar
Good info. Thanks Brian!
rgoers
03-25-2012 11:07 AM
olderthandirt
11-21-2008 10:28 PM
pvr02
Ninja 250R
10-06-2007 02:19 PM
pvr02
Ninja 250R
07-09-2007 11:47 PM
ntloser
10-23-2006 02:07 PM
Quick Reply: Rear brake lever position
