Rear brake lever position
When I sit normally on the bike, the position of the rear brake lever seems really too high. I have to lift my foot from the peg to apply rear brake. Do you have the same problem?
RE: Rear brake lever position
ORIGINAL: KLXer
You can adjust the position to your liking.
Oh man I have the same problem, it wasn't bad when I just had hiking boots on but with 10" steel toe workboots (compromise for work comfort and some street protection) I have to take my foot off the peg to use the rear brake, especially if I'm standing up. So what did you guys do to lower the pedal? The one on my Yamaha Warrior atv had an adjustable stop point with a long turnbuckle on it but the only thing I could think of doing with the KLX setup is to screw in the plunger rod but I don't see much adjustment there so I left it alone.
ORIGINAL: bryantjt
