Rear blinkers
Old Jun 21, 2018 | 07:31 PM
addictedtogum's Avatar
Default Rear blinkers
Due to the rear blinkers breaking when I drop the bike I would like to replace them with some flush mounted ones. I really like the looks of the below setup, but all the links are broken. Any idea which blinkers and taillights these are? I own an '06 BTW
Originally Posted by deej
Here are a couple of pics and links. You can also see the Tail light that we used to get rid of all the junk hanging down past the fender. Good luck.
Attachment 31252
Attachment 31253
Attachment 31254
Here are some links.
http://www.motorcycle-superstore.com/item.aspx?style=10822&department=661&Divis ion=6
http://www.motorcycle-superstore.com/item.aspx?style=14600&department=661&divis ion=6
http://www.acerbis.com/p106_handguard/1326.html
http://www.cyclepages.com/ProductGroupDisp.aspx?ProductGroupID=4002724
Well there you go, it took me a while to find all the places and pics, I hope this helps. Later man.
Old Jun 21, 2018 | 09:08 PM
Brieninsac's Avatar
These are the ones I replaced mine with.
https://www.cyclegear.com/parts/spee...d-turn-signals
They're $20 at Cycle Gear and don't stick out as much. I bought them because my exhaust was melting the stock ones, a common problem with these bikes.
Old Jun 21, 2018 | 10:08 PM
GBAUTO's Avatar
I used a set of Bikemaster generic amber marker lamps-work very well for the past 5 years. https://bikemaster.com/motorcycle-re...lear-bulb.html
Old Jun 22, 2018 | 01:21 PM
One rider here did some press in semi-trailer clearance lights, but I cannot find the post. They were like $5 each, I bought four and will eventually install them. They were LED. Drill a hole, put in grommet, press in the LED/lense and done, wire it up. Not the most handsome set up, but I planned to do them either behind the side number plates or on the license plate set up for the rear.
I know the post is here and/or at ADVrider in the Long Term KLX250 thread.
Old Jun 25, 2018 | 03:00 AM
azdeuce's Avatar
Default Blinker
yep cycle gear also.. put tears on because of that FmF meltdown...
Old Jun 25, 2018 | 03:01 AM
azdeuce's Avatar
Default Blinker
yep cycle gear also.. put rear ones on because of that FmF meltdown...
Old Jun 25, 2018 | 05:00 AM
RaceGass's Avatar
Just put some on a wr450f , I knew one day id use the cut off pieces when I narrowed some bars. I used a portaband lol
Old Jun 25, 2018 | 11:34 AM
I found RockabillSlapatt's LED signal set up. Low buck easy to do and virtually impervious to damage.
Old Jun 25, 2018 | 02:18 PM
RageHardIntoTheBendies's Avatar
I just use stick on LED strips, very bright and tough
Will do front ones on the hand guards as soon as my electronic relay shows up.
Old Jun 25, 2018 | 09:35 PM
another interesting approach.
DonnyKLX09
Apr 8, 2008 01:11 PM
MaverickAus
Dec 6, 2007 05:12 AM
kidpjs2112
Jun 20, 2007 02:44 PM
uneducatedstudent
Sep 9, 2006 06:20 PM
sup_uni
Aug 21, 2006 06:27 AM
