Random Whistling/Squeaking noise?????????
Old Sep 2, 2009 | 04:48 PM
DSBoomerRider's Avatar
You can tell I have never worked with a speedometer before. I realized all of this and my mistakes now....................... I thought even though it was electric there was still a mechanical side to it and the reading end on the tire or what ever ......
I'm going to sit facing the corner now......
Old Sep 2, 2009 | 04:51 PM
dw108's Avatar
right you are. didn't think about that. Noise I had wasn't really a whistle either, but seemed to be coming from right front around the speedo housing - lubed it and it stopped. Not sure how lube would fix a whistle from the pick up, but if it worked for red - worth trying.
Old Sep 2, 2009 | 07:27 PM
Mudhore's Avatar
Don't know if this is the noise you are hearing but try putting a thin coat of oil where you seat attaches to your gas tank and see if that makes the noise go away....
Old Sep 3, 2009 | 01:04 AM
LearjetMinako's Avatar
Sounds like something loosened up. Re-check your work for anything that you may have forgotten to tighten. Also check the bolts for the plastics, tank, and seat.
Old Sep 3, 2009 | 03:03 PM
Thanks for the help guys. It's all worth a try really.
It's not even that bad and I notice this morning riding that it's a squeak more then anything else and it show's up on the right front side of the bike(I think lol). When I'm going around 25km/h it starts to squeak consistently then stops for a second then starts again when I start slowing down to stop. I don't think it's the brakes because it happens even when I don't use them to slow down.
Old Sep 3, 2009 | 10:27 PM
redpillar's Avatar
did you spray the speedo pick up? just blast the whole thing with wd 40 no need to take anything apart.
Old Sep 4, 2009 | 12:58 PM
I did on the outside of it (between the housing of it and the right fork) but didn't notice any change.
larry0071
Sep 17, 2021 03:25 AM
Jon500r
Ninja 500R
Oct 22, 2007 08:18 PM
Pbce888
Aug 4, 2007 10:46 PM
frrogger1
Jun 17, 2006 04:29 AM
50 Slider
May 7, 2006 11:18 AM
