quick double check
Old Mar 8, 2012 | 12:58 AM
treerat's Avatar
Default quick double check
Getting the 09 klx 250 outa the garage in two weeks. It's basically spring. Anyhow, i'm ordering a bunch of stuff.... tires and filter. Anyhow i figure it's about time to jet the bike. Placing my order with RM ATV. They offer a dyno jet kit. The bike has the stock muffler still, uni filter, planning on getting a kdx snorkel..... Where's the best place to get the snorkel. My main concern with the dyno jet kit is it doesn't have a pilot jet. Do I need to replace the pilot jet. I'm at sea level. Also plan to drill the starter jet #77.
Old Mar 8, 2012 | 01:04 AM
BigSky KLX's Avatar
No, you don't need to touch the pilot jet.
Old Mar 8, 2012 | 01:10 AM
treerat's Avatar
awesome, i'll just replace the main and needle.
Old Mar 8, 2012 | 03:32 AM
Brewster's Avatar
If you haven't already done so, you will have to gain access to the pilot screw to adjust the idle mixture.
Ride on
Brewster
Old Mar 8, 2012 | 01:42 PM
treerat's Avatar
my plan is to just follow the instructions, just making sure all that I need is in this kit.
Old Mar 8, 2012 | 02:00 PM
There is a cap over the air fuel screw. You have to remove it to adjust it, and it needs adjusted. The KDX snorkel is a waste. I have one sittin in a box. I just took the snorkel out all together.
Old Mar 8, 2012 | 08:40 PM
treerat's Avatar
I understand the fuel screw part of it so it should be simple and straight forward. Lots of debate about the snorkel tho. I wonder what the air flow rate difference would be with the kdx or just removing the snorkel.
Old Mar 8, 2012 | 09:10 PM
ahnh666's Avatar
jetted without the snorkel....i was getting uncomfortable vibrations on my crotch (girls might like it)...i use my klx250sf for high speed/high rpm long distance commutes...installed a kdx snorkel and problem solved....and, bike was still running smooth with the same configurations...that's only difference i can tell...it's quieter and less vibrations with the kdx snorkel..power wise?...i couldn't tell...
Old Mar 8, 2012 | 09:15 PM
Brieninsac's Avatar
I took my stock snorkel out for a day and hated it. My bike was louder and vibrated more. I put in a KDX snorkel and have been very happy with it. I'm getting more air in without the noise or vibration.
Old Mar 8, 2012 | 09:20 PM
ahnh666's Avatar
+1 ditto...
