Rear Break Squeking
Old 05-16-2018, 05:47 PM
KawasakiKid's Avatar
Default Rear Break Squeking
I have recently noticed that my rear brake has started to squeal and squeak. This is happening whether I apply the brakes or not! If I roll the bike in neutral I can hear it. Any ideas on how I could fix this I’d rather not buy new brakes right now money is kind of tight 😬 Thanks!
Old 05-16-2018, 07:29 PM
canklx's Avatar
You might have gravel stuck between the brake pads and rotor. Try pushing the caliper piston in and flush with water. This is assuming your pads are not worn out and down to metal on metal.
Old 05-16-2018, 08:34 PM
That and sand the brake pads with some 80 grit sandpaper. You could scuff the rotor a bit too. Certainly won't hurt.
Also grease the pins) the caliper slides on, it floats as well as a really light coat on the pins that hold the pads. That allows the caliper to move and the pads to retract easier. It is possible the caliper is hanging up.
Old 05-17-2018, 01:36 AM
RaceGass's Avatar
If those don't do the trick...
pull the caliper and push on the brakes to see if the pads/pistons are working properly/extending correctly and EVENLY. If not pull the pads and clean the pistons with something like wd40 something that won't affect the piston seals. Push the pistons back to their original position, extend the pistons again. Clean again if needed. Sand the pad pins like was said above if they have any irregularities then grease lightly and reinstall everything.
Hopefully your brakes won't be hindered causing any noises.
Old 05-17-2018, 01:38 AM
Those are all great tips thanks
Old 05-17-2018, 03:26 PM
Don't ask how we learned them...
Dustin Mobley
KX100
03-04-2017 04:25 AM
exalted512
Ninja 500R
05-30-2008 03:13 PM
MONSTA NYC
09-26-2006 05:37 AM
MONSTA NYC
09-25-2006 03:51 PM
greenrider
06-07-2005 06:17 AM
Quick Reply: Rear Break Squeking
