Q on measuring valve clearance
Old Jul 17, 2013 | 11:22 PM
ahnh666's Avatar
also, just because it's at "T" doesn't mean it's at TDC...you have to stand up and visually inspect it and sometimes takes a few rotations to be be at TDC...
Originally Posted by durielk
nm.... looks like you got a mechanic on the next page of the thread..... he probably did my recommendation which was....
Rotate the crank 360 degrees (one revolution) and re-measure. I can't believe there is absolutely no clearance.
Old Jul 17, 2013 | 11:43 PM
ol'klx-er's Avatar
For a valve clearance check, you want the motor at the TDC where the lobes of both cams are up(ish) and pointing away from the other cam.
Old Jul 18, 2013 | 12:59 AM
Elvie's Avatar
Good info on the T location and where TDC actually is located.
Spun the crank a few times and watched the lobe alignment themselves. The T is actually just a tiny smidge before the beginning of the notch - but my measured clearances remain the same.
Can anyone verify this for me as the correct shim kit:
Hot Cams 7.48mm Complete Valve Shim Kit HCSHIM01
Thanks all.
Old Jul 18, 2013 | 02:42 AM
durielk's Avatar
Originally Posted by Elvie
I tried the .003 in (my smallest) on the LHS inlet and it would not fit.
The bike is 2009 with 8000K - 98% dirt. It starts and runs well.
This remanded the same?
Old Jul 18, 2013 | 11:26 AM
250SM's Avatar
Thats the right kit, $80 shipped from the U.S and only used 1 shim.
Old Aug 1, 2013 | 02:12 PM
Elvie's Avatar
Default Just to close the loop
Have the 330 kit installed and had a few rides. Valves adjusted as well.
Great little performance upgrade. Pulls better everywhere and now has a kick between 5500 and 8000 RPM. Did require a main jet change from DJ128 to DJ 132 to supply enough gas after 7500 RPM.
Thanks to everyone for their insights and advice.
Old Aug 2, 2013 | 04:26 PM
grahamgower's Avatar
Hey Elvie, what other mods, such as intake and exhaust have you done. I have just completed my KK 331 instalation on an EFI bike and am experiencing huge changes to my jetting. I went from 300 to 331 and have had to change jetting across the whole range. ( Electronic mapping changes)
I experienced a substantial power boost with the extra cc, however this may also be due to the Webcams that I did at the same time.
Old Aug 2, 2013 | 09:58 PM
  #28
Elvie's Avatar
Other upgrades have included a full Muzzy exhaust, BB block off plate, air box lid removed and an aftermarket air filter - and of course the DynoJet Stage 2 with a switch to the 132 main jet. Otherwise the carb settings are fine.
teddybear
Jan 28, 2009 07:27 AM
chris72a
Apr 5, 2008 01:39 AM
Sturgell
Nov 15, 2007 04:27 PM
stunner388
Oct 10, 2007 02:05 PM
Ginsu4u
KLX125 & KLX125L
Sep 10, 2006 09:49 AM
