putting a new brake light in
Old Mar 5, 2016 | 08:53 PM
7layercooki's Avatar
Default putting a new brake light in
2009 klx250s okay so when I got my bike there was not brake light or turn signals in the rear I'm wanting to know witch wire goes to what? I have 3 black/yellow wires, 1 white wire, 1 blue/white wire, 1 green wire, 1 red wire.
and my new taillight has turn signals built into them is
ground:black
running:green
Brake:red
left turn:yellow
right turn:white
I'm far from a electrictian any help would be awesome
Old Mar 13, 2016 | 12:44 AM
KLX25O's Avatar
do you have the switches that control the brake light?
turn signal switch brake light switch for front and rear brakes?
you can hook a test light up to the wires, and push the brake, and *if the test light "glows" that's the brake light wire, same for left and right turn signals.
hook the test light to the wire and push the turn signal switch left/or right, and the test light should blink on and off,
that will help you a little.
splice your wires according to the schematic into the bikes harness once your sure everything is right.
as far as color code I can't really remember but I think I mentioned it in one my videos when I put a signal dynamics license plate frame on mine a while back,
roccitman
Dec 16, 2015 05:32 AM
Tdizzle
Apr 18, 2009 06:29 PM
frrogger1
Mar 15, 2006 06:50 PM
MAD KAW
Aug 31, 2005 02:12 AM
ntence
Aug 4, 2005 10:21 AM
