putting a new brake light in
2009 klx250s okay so when I got my bike there was not brake light or turn signals in the rear I'm wanting to know witch wire goes to what? I have 3 black/yellow wires, 1 white wire, 1 blue/white wire, 1 green wire, 1 red wire.
and my new taillight has turn signals built into them is ground:black running:green Brake:red left turn:yellow right turn:white I'm far from a electrictian any help would be awesome |
do you have the switches that control the brake light?
turn signal switch brake light switch for front and rear brakes? you can hook a test light up to the wires, and push the brake, and *if the test light "glows" that's the brake light wire, same for left and right turn signals. hook the test light to the wire and push the turn signal switch left/or right, and the test light should blink on and off, that will help you a little. splice your wires according to the schematic into the bikes harness once your sure everything is right. as far as color code I can't really remember but I think I mentioned it in one my videos when I put a signal dynamics license plate frame on mine a while back, |
