Pumper Carb
Old Sep 15, 2013 | 11:43 PM
klx250s_rider's Avatar
Default Pumper Carb
I've just about had it with my stock (rejected) Keihin carb - So which Mikuni should I replace it with?
Old Sep 16, 2013 | 12:45 AM
My vote is for the TM36-68. It's practically a straight bolt-on. It's cheaper than Bill's modded 34mm carb. It's more tuneable than the 33/34 Mikuni. The basic jetting has been fairly hammered out thanks to Mustang and Dan Moore. The 2 extra millimeters of carb venturi don't seem to be too much for the stock 250, and I'll contend the 36mm carb will definitely be more beneficial with a bigger bore kit. That said, there's nothing wrong with Bill's modded 34mm carb. I just think there are a couple of extra benefits with the TM36. I've been running one for nearly a year now with excellent results on 250S with a 300 cylinder. I've gotten amazing fuel mileage with this thing too, which I didn't really expect.
Old Sep 16, 2013 | 02:18 AM
THX, Sounds good - Is there a specific model number? Where did you buy yours?
Old Sep 16, 2013 | 03:57 AM
Brieninsac's Avatar
I've been contiplating replacing my carb too. It's unlikely I'll ever do a big bore though. What can you expect performance wise from say the TM36-68?
Old Sep 16, 2013 | 05:43 AM
There's probably some source that has dyno'd the KLX with Bill's carb on it, but I don't know where it is. Some say that a pumper carb will only improve the response...a result of the squirter. I'm pretty sure that a KLX with an free-flowing airbox and full exhaust benefits at wide-open-throttle too. I know mine definitely pulled better and quicker to top speed with the 36 pumper. Kind of makes sense when you consider the totally smooth bore of these pumper carbs compared to the throttle plate and shaft obstruction the CV carb has. The bike is a whole lot more fun to ride. I probably wouldn't consider the 34 or 36 pumper unless I had an aftermarket exhaust. I don't think it would yield as noticeable a performance increase.
To the original poster...the model is a Mikuni TM36-68 as stated above. I got mine through my local motorcycle shop, but it actually came from a large wholesale distributor named Tucker/Rocky. There are numerous sources for this carb. You also need the appropriate jets for the KLX application.
Old Sep 16, 2013 | 10:30 AM
zippets's Avatar
i have to say its like night and day
i placed one on my bike last month and wow no effort 2nd gear wheelies
and im still a 250
Old Sep 16, 2013 | 01:43 PM
and im still a 250
zippets, what final jetting did you end up with from our conversations on PM's?
Old Sep 17, 2013 | 09:40 AM
zippets's Avatar
im still running the same as suggested 1.0 air jet though
waiting till over the winter for bbk
the bike is running awesome it is big help in sugar sand
Arctra
Nov 21, 2010 11:48 AM
horizonod
Nov 15, 2008 12:38 PM
EMS_0525
Sep 9, 2006 05:53 PM
Montana Tracy
Aug 7, 2006 04:27 AM
954ken
Jun 8, 2006 08:57 PM
