pulley twist grip
Old Apr 2, 2007 | 08:57 PM
markturbo's Avatar
Default RE: pulley twist grip
I always wanted to do that mod!
Old Aug 16, 2007 | 08:20 AM
sinkoman's Avatar
Sorry, don't mean to dredge an old thread, but this genuinely interests me.
If I were to look on ebay for old throttle assemblys to do this mod, what bikes in particular should be looking for?
I just really don't know much about these push pull systems, and what sort of traditional ones will be compatible with it.
Old Aug 16, 2007 | 12:50 PM
mustang's Avatar
I'm not sure which OEM throttles will work, but you can get pretty much any Motion Pro throttle to do the job. Mine is a Magura 314 - http://www.motionpro.com/motorcycle/...pull_throttle/. You can use the stock throttle cable with this throttle without problem, and it has 2 ratios - MX and Enduro. The MX ration is a pure 1/4-turn, while the Enduro is about a 3/8-turn. All you need to do is turn the throttle tube 180 degrees and reconnect the throttle cable to change ratios.
With any of the pulley-type throttles, you have to rotate the throttle to clear the right mirror, but otherwise, it's a straight bolt-on. Here's mine:
In the pic, it has a Four Stroke Works cable on it which I could only get adjusted by turning everything completely out. I put the stock cable back on and all was well.
Old Aug 16, 2007 | 09:53 PM
sinkoman's Avatar
Dang, I was looking for OEM throttles because they're like 2 or 3 bucks a pop on Ebay
Anybody else have any idea which OEM throttles will fit on? I'd love to invest in either a Vortex, Turbo, or Magura throttle, but 40 bucks for a throttle system? No thanks.
Old Aug 17, 2007 | 06:39 PM
britboard's Avatar
any kx250 twist grip will do you, just follow the instructions on the first post.
Old Aug 18, 2007 | 12:11 AM
sinkoman's Avatar
ORIGINAL: britboard
Thankyou
What is the advantage of the 1/2 turn throttle when you're in the trails? I noticed that most 3/8 or 1/2 turns are labeled as "enduro" throttles, and i'm wondering if that 1/4 turn would be a burden in the trails.
JayBoogie81
Apr 30, 2009 07:04 PM
rprun54
Mar 19, 2009 01:51 PM
markturbo
Feb 16, 2007 05:59 AM
cwgoff
Oct 2, 2006 03:53 PM
ZX_9r
Ninja ZX-9R
Jun 24, 2006 05:02 PM
