Proper way to check oil level?
Old May 28, 2008 | 01:52 AM
bsambuco's Avatar
Default Proper way to check oil level?
Noob question...what is the proper way to check the oil level in the sight window? While the bike is on the sidestand or balanced upright? The manual says "parallel to the ground" so I interpret that to mean balanced upright. Am I correct?
Old May 28, 2008 | 02:06 AM
lcpl0331's Avatar
Default RE: Proper way to check oil level?
yes you are. off the kickstand no lean. shouldn't it say "perpendicular to the ground"?
Old May 28, 2008 | 02:32 AM
bsambuco's Avatar
You're correct...perpendicular to the ground. Thanks for the quick answer.
Old May 30, 2008 | 02:09 AM
adaycj's Avatar
Before I ride I just start to tilt it up off the stand. If I see the oil start to climb the window I already know I have enough oil.
stephenmarklay
Jun 11, 2012 02:06 AM
fixin737s
800, 800 Classic & 800 Drifter
Jun 10, 2008 07:59 PM
travis82
Ninja 500R
15
Jul 20, 2007 12:44 PM
rayw1128
Jun 25, 2007 06:35 AM
Marty
Aug 24, 2006 05:31 PM
