Problem after trying the lidless setup
Old Mar 29, 2022 | 10:36 PM
Klxster's Avatar
Nice Jaksno !
Old Mar 29, 2022 | 10:39 PM
fordtruck's Avatar
Originally Posted by Klxster
Really good job finding and fixing the diaphragm issue @fordtruck..
As you probably know, the lidless setups are not experimental - If the bike doesn't run right after the carb session, something was done wrong..
Also, as you know, the lidless setups unleash power that leaves "normal" KLX builds in the dust..
The MCM is an enhancement of volumetric efficiency through valvetrain retiming. It is proven very effective thru dyno charting. As such, it does the same "goodness" regardless of what size piston is in the bore.
The MCM is not experimental. If it is done correctly, it works.
As you have found out for yourself, if you want enhanced low - mid TRQ with little-to-none HP loss in the top end, you do the MCM.
I'll be honest, I'm a little disappointed in the MCM. I guess I was expecting more. I think I did it correctly. I need to ride my bike and my son's back to back and compare. Our bikes are pretty much identical except we have not done the MCM on his.
Now the lidless setup is a different story. I'm very impressed with it. I already had the Stage 2 Dynojet kit in mine and it still added quite a bit over that.
Old Mar 30, 2022 | 03:01 PM
Klxster's Avatar
Here is the comparison chart - DO NOT make the mistake of looking at the HP curves, that is useless information. ONLY THE TRQ CURVES have useful information.
This comparison chart is imperfect due to the MCM bike (blue lines) not being fully/final tuned at the time of this dyno run AND due to the run not being started at a lower RPM - but the two bikes are outfitted identically otherwise.
Differences between MCM and Stock can be deduced - but the slight losses, for the MCM, in the upper end are probably due to the incorrect carb tune.
In a nutshell: You are looking at significant increases in throttle response and power ramp-up below 6500 rpm and, basically, parity above.
Old Apr 24, 2022 | 03:02 AM
fordtruck's Avatar
Well after fine tuning the idle mixture screw to halfway between idle drops and putting a few hundred miles on the bike, I've changed my opinion on the MCM. Adjusting the mixture helped the flat spot off idle. The bike really feels responsive above 4.5k rpms. Doing the MCM and lidless setup really woke this bike up.
Old Apr 25, 2022 | 02:56 PM
Klxster's Avatar
Now that you've properly set the idle mixture screw - and I hope your idle speed it also set correctly - you have fully "fleshed out" your build - great job!
For the record, an integral part of the lidless recipes is the proper setup and selection of the pilot jet and pilot system - this information is included and specified in each of the lidless recipes.
As @fordtruck found out - a lidless recipe is not complete - and the full performance benefit is not available - until the directions for the pilot system are followed.
This is doubly so for lidless builds that include the MCM. The proper setup of the pilot system is vital in order for the CVK to provide an enhanced "shot of fuel" every time the throttle is snapped. In the case of lidless builds that include the MCM, this allows for the "full effect" of the enhanced TRQ, and enhanced TRQ ramp-up offered by the MCM.
Old May 3, 2022 | 04:13 AM
ekim250's Avatar
I did the lidless and kept the stock Pilot jet. No problems. Still very happy with the power increase after two years.
Old May 3, 2022 | 08:17 PM
Klxster's Avatar
Replacing the pilot jet with a #38 or #40 is not always "mandatory" with lidless setups ( I will explain below) .. But, properly setting the fuel screw is mandatory.
About replacing the pilot jet:
When the MCM is included in your lidless build - the pilot jet should be replaced with a #38 or a #40, along with proper fuel screw setup. Use the #38 only if your bike stays above 3000 ft above sea level.
If the MCM is NOT included with your lidless build but you are using the stock header, a new pilot jet is recommended.
If not using MCM and using a full performance exhaust, pilot jet replacement is totally optional.
queen of spades
May 30, 2016 08:43 PM
CC_Rider
Oct 26, 2014 10:44 PM
Mammothmafia
Jul 25, 2013 03:14 AM
T_i_G_e_R
Mar 23, 2011 03:28 PM
