Pics of the bike
Old Mar 27, 2008 | 08:09 PM
  #31
2k1w=no$'s Avatar
Default RE: Pics of the bike
I had no problems with the front fender. Some others on here are using the same fender and had to make shims to get it to fit. One thing I did do was, on the stock fender there are metal washers that are pressed it the mounting holes. I took them out and put them in the new fender. With them in there the fender just touched the frame in the back(not hit just skimmed it) it probably would have been alright but I put a 1/4 stainless washer under the rear bolts which was about .050" thick. Problem solved but a .025" shim would have worked too.
I think the fender was $17 from Rocky mountain.
Old Mar 27, 2008 | 08:17 PM
  #32
stellar_d's Avatar
awesome thanks dood!
Old Mar 28, 2008 | 06:30 PM
  #33
stellar_d's Avatar
Just ordered up the front fender from dennis kirk. 25 bucks with shipping to my place in whitefish. Hopefully it doesnt have issues rubbing against the UNabiker rad guards.
Is this fender a little more stiff than the stocker? I find the stocker causes wobble with the wind.
Old Mar 28, 2008 | 07:51 PM
  #34
2k1w=no$'s Avatar
It says it is designed to be stiffer. but I don't know for sure if it is or not.
Old Mar 28, 2008 | 07:52 PM
  #35
dirt_beaver's Avatar
I've got the cyrca front too, seems to be a little stiffer...
Old Mar 28, 2008 | 08:57 PM
  #36
stellar_d's Avatar
being only 18 bucks, if all it does is look good then its money well spent
Old Mar 28, 2008 | 11:42 PM
  #37
tremor38's Avatar
If you are talking about the wobble you get at higher speeds, I doubt the fender is causing that. I say this because I still had the wobble after switching to the Acerbis Supermoto fender. All it takes to induce it is sharp steering inputs at higher speeds. It think it has more to do with the geometry of our bike.
ORIGINAL: stellar_d
jsac
Nov 11, 2008 08:05 PM
cliffsta
Sep 11, 2008 05:51 PM
EMS_0525
Dec 19, 2007 03:23 AM
