pic of klx 250 rear end
Old Sep 8, 2013 | 01:43 AM
fenderworks2's Avatar
Default pic of klx 250 rear end
just finished my rear fender mod.....took 20 min. and no swear words
my pics suck
Attached Thumbnails pic of klx 250 rear end-p9070013.jpg   pic of klx 250 rear end-p9070021.jpg
Old Sep 8, 2013 | 02:51 PM
Here's mine.
Old Sep 9, 2013 | 03:13 PM
Deej,
yea i like your look, it has a light on the plate.
i dont have a clear light on my plate, so night riding the popo would be after me.
got to work on that
Old Sep 9, 2013 | 03:27 PM
Originally Posted by fenderworks2
Deej,
got to work on that
You can also get a small, cheap license plate light and mount it above the plate. Most of them seem to need some additional water sealing with a little silicone, but that's easy. We have an annual motor vehicle safety inspection here in Texas, so it's pretty much required to have a plate light.
Old Sep 9, 2013 | 04:10 PM
I used these for a little while. LED License Plate Lamp Bolts.
US SHIP White LED SMD Motorcycle Car License Plate Screw Bolt Light Lamp Bulb | eBay
Old Sep 9, 2013 | 04:17 PM
Hmmm...that looks cool, Scott, but why did you only use them for a little while?
Old Sep 9, 2013 | 08:50 PM
There's a story, of course. This is the only pic I could find with them installed.
My license plate began to fatigue crack. When taking it all apart, I cut the wires to the little lamps (didn't have connectors under the fender, just soldered and heat shrink), attached the plate to some more solid material, and put the plate back on. I couldn't get the old lamps to fit back in after doing this, due to wiring issues (the thick marine-grade heat shrink was too thick to get the lamp attaching nut off and back on). I have new replacement lamps and plan on installing sometime this winter. The tail light shines enough that I could probably get away with it, but will do it proper with lamps here in a few months.
I was using the old plate attachment bracket and the top two plate holes. Now, with the thicker backing, the plate is mounted to the bracket closer to the middle of the plate. Here's the best pick I could find.
The lamps stick out a little ways, but they were bright and solid enough I would recommend them.
Old Sep 10, 2013 | 02:49 AM
IDRIDR,
thanks for the tip on those little LED on ebay, I will pick up a couple. I am thinking I will only mount 1 of them above the plate, or somehow In the plate.
funny how I thought about this mod for a while. it was too easy, but I only lost about 1 pound of weight. I was thinking that low plate/light assembly would weigh 5 pounds or more...........oh well
Old Sep 10, 2013 | 02:56 AM
well it took me 10 min. to think about it, I bought 2 of the led lights. should be a no brainer 10 min. job to install.( for me that means 2 hours)
TNC,
thanks for your input also
nhjake
Jun 11, 2015 10:07 PM
Mike Fournier
Mar 2, 2015 05:36 AM
horizonod
Nov 6, 2008 12:48 AM
big lou
Mar 31, 2008 02:53 PM
