Old swingarm with snail adjusters
Old Mar 8, 2024 | 10:03 PM
freakdaddy's Avatar
Default Old swingarm with snail adjusters
Replaced my 2018 KLX 250s D-shaped swingarm with screw-locknut adjusters with 1st. generation swingarm and snail adjusters for less than $50 from eBay. Quick positive chain alignment and tensioning with snails. And easier rear tire removal.
Steve J ‘18 KLX 250 SoCal
Old Mar 9, 2024 | 02:03 AM
1994klr250's Avatar
I always preferred the snail style axle adjusters. My 06 klx has then as well as my klr250. Your definitely correct that it makes chain tension easier and quicker. Thanks for letting us know it's a direct swap.
Old Apr 7, 2025 | 05:37 AM
tsc's Avatar
tsc
Thanks for sharing. I was looking for exactly the same information, if the swingarms are interchangable.
Old Apr 7, 2025 | 12:09 PM
I measure from the swing arm pivot to the axle center, making it equal on both sides. Doesn't matter how the adjusters work, snail cam or threaded adjusters. Just a way to know without question and only takes a minute.
Old Apr 7, 2025 | 12:49 PM
tsc's Avatar
tsc
True, but you need to have both swingarms on hand to confirm.
Old Apr 8, 2025 | 10:49 AM
You missed what I was saying. I was saying that I use the measure when adjusting the chain. I have found that marks on swing arms and adjusters aren't always perfect, so I measure to make sure the distance is equal side to side. When I measure say 28-1/4" on one side the other side must be adjusted to the same 28-1/4" otherwise I need to either move one back or the other forward to get matching measures.
Whether the two swing arms are the same length in comparison was not the point. I'm sorry I wasn't clearer on that.
donaldor
Oct 17, 2025 10:42 AM
popy28304
Oct 11, 2013 04:55 PM
popy28304
Classic Sportbikes
Oct 6, 2013 12:36 AM
CDN ZX6r
Mar 20, 2010 06:00 AM
dxrich
May 29, 2008 10:15 AM
