old gas (two weeks old) no start
Old Dec 26, 2020 | 01:13 AM
azdeuce's Avatar
Default Old gas nah
Ok I need to reply... my gas in the bike is like 8 mo old and I start my bike once a month.. it starts right up.. it’s jeted
and a pipe with a 300 snorkel
so old gas and all it works fine..
Old Dec 26, 2020 | 10:37 AM
Yep, gas in Oregon is the same as gas in Texas, is the same as gas in Michgan, is same as gas in North Carolina and the gas is the same from station to station...
Really, gas blends vary around the country as well as depending on season and the company producing the gas. Winter blend is different than summer blend.in Ohio. It affects the performance of the gas. So clearly your performance may vary.
Old Dec 26, 2020 | 01:53 PM
It still comes back to the fact that not all KLX250's behave the same as this fuel, jetting, starter jet, etc. issues apply to cold starting. Some bikes have no issue with cold starts even with stock jetting and fuel older than 2 weeks. Some require starter jet drilling. Some require the fuel level to be set. Some require a "better" jetting combination than stock. Etc., etc., etc. There is no "one" issue as it pertains to cold starting with these bikes as I've said all along.
Old Dec 26, 2020 | 05:26 PM
Klxster's Avatar
I did find a solution for hard/no start after sitting..
Run 100LL ..
Av gas will destroy any catalyst (nonissue since I run full FMF systems) and most won't have 100LL in the garage.. There's also likely a power loss due to the slow burn rate of the (unnecessary) higher octane fuel(s).
Other than this non-solution, if a KLX is hard to start after a few days sitting, draining the bowl a little or using @ekim250 's shake method are two solutions that ARE doable..
Old Dec 27, 2020 | 02:08 AM
Well, if you must shake your KLX to make it start, at least do it right...
You put your right foot in,
You put your right foot out,
And you shake it all about
You do the Hokey Pokey and you turn yourself around
That's what it's all about.
...that is if you want to start your KLX.
daren1093251
Apr 12, 2014 11:10 PM
kingocean
Jul 6, 2013 09:04 AM
dilman106
Aug 2, 2009 07:12 AM
klx250smass
KLR250
Jan 5, 2008 01:12 PM
nemo_7708
KLR250
Apr 3, 2007 05:50 PM
