Ok I installed the Dyno Jet kit
Old Apr 10, 2006 | 05:05 AM
  #61
motoguy128's Avatar
Default RE: Ok I installed the Dyno Jet kit
OK, I put the 128 back in and left the pilot air screw at 2 turns out and left the dynojet needle in on the 2nd slot from the base. I rode 145 miles this afternoon, mostly on gravel road at 40-60mph with some paved roads at 60-70mph. I got on it pretty hard exiting corners but otherwise rode a constant speed. I averaged 61mpg using 91 Octane premium. I still might try a 126, especially when it warms up this summer, I expect it to richen up a little, but for now it's fine. I think the popping is unavoidable and probably mostly a result of the dynojet needle and the larger hole in the slide.
Old Apr 10, 2006 | 05:11 AM
  #62
incabiker's Avatar
Nice, thanks for the report. I also pulled my needle today and moved it from the 3 slot from base to the 1st slot. It felt better all around but the popping is still there deacelerating at about 5-4,000 rpms. So with the e-clip in the 1st slot I should be saving myself a little bit of gas.
Old May 1, 2006 | 08:15 AM
  #63
NavKLX's Avatar
I had the same problem with popping on deceleration. I've got a FSW full exhaust, 128 MJ, dynojet needle on 3rd groove, air-fuel screw 2.5 turns out. In my case the popping came when I went to fully closed throttle from WOT. Bill_P over at Thumper Talk suggested bumping up pilot jet up a size or two. I tried that and the popping is 90% gone. Im now running a #38 PJ. #40 PJ might be better. Bike runs great tho, FWIW.
Old May 1, 2006 | 05:19 PM
  #64
bmwhd's Avatar
ORIGINAL: NavKLX
Ding Ding Ding! We have a winner. That's exactly right. Around-town MPG may suffer a bit but the popping will go down.
treerat
Mar 23, 2012 07:36 PM
jhoffy22
Jun 25, 2011 09:14 PM
oregon dual sport
May 21, 2007 04:32 AM
JazZ023
Aug 19, 2006 12:38 AM
joker7337
May 2, 2006 01:46 AM
