Oil Filter toqure?
Old 02-19-2011, 06:50 PM
TexasKawai's Avatar
Question Oil Filter torque?
Looking in the service manual there isn't a torque spec specifically for the bolts on the cover plate for the oil filter. If you look in the manual there is a torque spec for an 8 mm bolt of 14 -19 nm. For those do it yourselfers do you go by this or do you just tighten until snug on these two bolts? I set my wrench for 15 nm and never got there before it felt like I was going to strip the bolts out.
Old 02-19-2011, 07:35 PM
ol'klx-er's Avatar
I went through the same thing recently. Lots of specs in the manual but nothing for that cover. It's got the o-ring in there, so I went with just snug which should be fine. I haven't run the bike yet since changing the oil & filter. It's still in the basement and the fuel tank is in the lawnmower shed. No gasoline in the house; natural gas furnace and hot water tank.
The bolts are 4 or 5 mm, the head is 8 mm.
Old 02-19-2011, 08:00 PM
dmar's Avatar
I just changed my oil and filter today. I just snug down with medium force. Don't over torque or you can strip the threads. BTW I layed the bike on it's side when changing the oil filter, that way the spring for the filter won't fall out of place.
Old 02-19-2011, 08:34 PM
TexasKawai's Avatar
Another way the manual says to do is to put greese on the filter and put the spring in the greese. This is the method I use to hold the spring on the filter. Works pretty well.
Old 02-19-2011, 08:37 PM
best trick to keep the spring in, is to bend the bottom of it open a little more. put the larger end of the spring in the bike, and never worry about it again.
Dan
Old 02-19-2011, 08:41 PM
TexasKawai's Avatar
Dan
That's a good idea. Was also thinking about geting a bigger round spring all together. My question would be is why didn't Kawasaki just make the tabs closer together to hold the current spring?
Old 02-19-2011, 11:46 PM
PSUdude85's Avatar
Snug is all you need since the O ring is in there. There is a thread somewhere on here where somebody broke the head of the bolt off b/c they over torqued it. If the cover leaks, you can always tighten it up a smidge if needed. I've tightened mine snugly last year and haven't had any issues.
As already mentioned a little grease or widening the spring will make your oil filter changes heck of a lot easier. Here's mine:
Highbeam
09-09-2022 11:26 AM
MJohnson
Ninja ZX-9R
03-20-2011 03:17 AM
yjsjin
07-12-2009 12:28 AM
bryantjt
09-22-2006 12:10 PM
Steve Ninja Strombol
Ninja 500R
05-13-2006 05:52 PM
Quick Reply: Oil Filter toqure?
