Oil Filter torque?
Looking in the service manual there isn't a torque spec specifically for the bolts on the cover plate for the oil filter. If you look in the manual there is a torque spec for an 8 mm bolt of 14 -19 nm. For those do it yourselfers do you go by this or do you just tighten until snug on these two bolts? I set my wrench for 15 nm and never got there before it felt like I was going to strip the bolts out.
I went through the same thing recently. Lots of specs in the manual but nothing for that cover. It's got the o-ring in there, so I went with just snug which should be fine. I haven't run the bike yet since changing the oil & filter. It's still in the basement and the fuel tank is in the lawnmower shed. No gasoline in the house; natural gas furnace and hot water tank.
The bolts are 4 or 5 mm, the head is 8 mm. |
I just changed my oil and filter today. I just snug down with medium force. Don't over torque or you can strip the threads. BTW I layed the bike on it's side when changing the oil filter, that way the spring for the filter won't fall out of place.
Originally Posted by dmar
(Post 438959)
best trick to keep the spring in, is to bend the bottom of it open a little more. put the larger end of the spring in the bike, and never worry about it again. :)
Dan |
Originally Posted by dan888
(Post 438964)
Dan |
1 Attachment(s)
Originally Posted by TexasKawai
(Post 438954)
As already mentioned a little grease or widening the spring will make your oil filter changes heck of a lot easier. Here's mine: Attachment 15461 |
