Oil filter spring trick to hold in place?
Old May 21, 2009 | 11:10 PM
RDHJ's Avatar
Default Oil filter spring trick to hold in place?
changing the oil for the first time on the KLX250 and see there is a spring behind the oil filter. is there an easy way to get the spring to stay in place as you push the filter in?
Old May 21, 2009 | 11:38 PM
Sid Post's Avatar
Take a pair of needlenose pliers and open one link of the spring enough to grab the teeth in the case. Insert filter, insert bolts, insert drain plug, add oil.
Old May 21, 2009 | 11:50 PM
molon labe's Avatar
I just drop my '06 onto it's left side and pop the spring and filter into place. Easy!
Old May 21, 2009 | 11:57 PM
buff36's Avatar
Grease on the spring. It disolves as it gets warm
Old May 22, 2009 | 12:00 AM
RDHJ's Avatar
Good, that is exactly what I did after I posted the question. You would think they would put a peg or something in there to hold the spring in place.
Old May 22, 2009 | 12:02 AM
Mudhore's Avatar
I have done the grease trick...works good!!!
Old May 22, 2009 | 12:03 AM
luvnidaho's Avatar
Just like the owner's manual says.
Old May 22, 2009 | 01:12 AM
RDHJ's Avatar
My owner manual doesnt even mention the spring..also checked the service manual and again no mention
Old May 22, 2009 | 01:57 AM
neilaction's Avatar
I lay mine down.
And sometimes I'm even changing the oil filter.
Old May 22, 2009 | 03:20 AM
Xplosivo1's Avatar
Wierd, my 09 manual specifically says to use grease to hold the spring in place.
