Oil filter spring trick to hold in place?
changing the oil for the first time on the KLX250 and see there is a spring behind the oil filter. is there an easy way to get the spring to stay in place as you push the filter in?
Good, that is exactly what I did after I posted the question. You would think they would put a peg or something in there to hold the spring in place.
Wierd, my 09 manual specifically says to use grease to hold the spring in place.
