Oil Filter Spring
Old Oct 10, 2007 | 09:04 PM
bryantjt's Avatar
Default RE: Oil Filter Spring
Don't lay the bike over with the petcock still on.........you'll get a nice puddle on your feet.....been there done that.
Old Oct 10, 2007 | 09:06 PM
ORIGINAL: bryantjt
Its not from the petcock, its from the carb bowl, unless you have ran it out of gas with the petcock off you will always get it... its dumpin gas from the carby.....
Old Oct 10, 2007 | 09:41 PM
LearjetMinako's Avatar
Yep, tweek the spring a little.
1st time I used a dab of greese. 2nd, 3rd, & 4th oil change, The spring was tweeked. Made changing the filter so much easier. So easy, I decided to change the oil at my work before I went home.
Old Oct 10, 2007 | 10:50 PM
My bike is used to taking a nap on her side ...... I just dump her in the garage and put the filter in. I did the grease trick once, too much work, dumping is faster.
Old Oct 11, 2007 | 12:31 AM
2k1w=no$'s Avatar
I use the lay it on the side method. I do run the carb dry before I do it though. I mat look into tweaking the spring next oil change.
Old Oct 11, 2007 | 12:38 AM
ZX1100F1's Avatar
Laying your bike on its side (opposed to tweaking the spring) is like spinning your car to tighten the oil filter. It will work but it sure is an unnecessary and awkward step in an otherwise easy process.
Old Oct 11, 2007 | 12:40 AM
hokie01's Avatar
I dab the grease trick,next change is the spring tweek
2007 Green Machine
Jun 29, 2020 02:00 PM
Bogiewan
KLX300R
Nov 26, 2012 11:16 PM
cwgoff
Apr 26, 2012 03:32 PM
RDHJ
May 24, 2009 04:18 AM
MADDOG2007
Jul 19, 2007 02:29 AM
