Newbie Question--removing exhaust/muffler
Old May 9, 2013 | 11:42 PM
ol'klx-er's Avatar
Lightbulb
Originally Posted by Brieninsac
If noise is a concern you may want to replace it with this muffler.
Is that available with a spark arrestor? Weight might be more than stock, yes no.
Old May 10, 2013 | 12:00 AM
wildcard's Avatar
If aftermarket exhaust is too loud but you don't want to fart around looking for a KLX300 muffler and header combo (need both as one won't fit without the other) follow these simple steps.
1. get stock 250 muffler
2. mod said muffler
3. look cool whilst doing so
4. profit
https://www.kawasakiforums.com/forum...inished-35018/
Old May 10, 2013 | 04:29 AM
mmmbeefy's Avatar
I put a TBR silencer tip on the TBR pipe on my R1 - It moved me from 98 db (failing) to 93 db (passing).
I also repacked the muffler while I was there, that might've helped too.
As for your search for a stock pipe and header, I'll trade you straight across!
Old May 10, 2013 | 10:23 PM
rgoers's Avatar
Originally Posted by klx4me
I made my own tip. At least I can hear the engine now. I rode around my house the other day without my helmet; still quite loud so I repacked it. I believe FMF are the way to go especially if you do a lot of commuting in suburbia.
Your 2nd picture reminded me that we need to deliver the standard warning to the OP that the FMF will melt his right turn-signal...
I think my slip-on is as quiet as the FMF, and it looks better, sounds better, and doesn't melt the turn-signal. DEP claims 92dB out of mine, but when I measured it was closer to 96dB (under standard measurement conditions).
Old May 11, 2013 | 12:15 AM
Ozawindib's Avatar
Thanks folks. No sooner got it all figured out, than the deal got away from me. <sigh...> Oh, well, my guess is that another KLX will show up on Craig's list sooner rather than later. Heaven forbid I should have to wait for a used CFR250L to come on the market.
Old May 11, 2013 | 08:07 PM
You may laugh at the concept, but some KLR riders have the ticket:
John Deere! Check out the details. Not a horribly bad idea. The side cover should have some insulation against the heat. Some riders weld on a turn down too.
I just communicated with a KLX650 owner who did this. Said it sounded good.
I'd try it on the aftermarket head pipe for good flow. It is a chambered muffler I believe, which means it will never need repacked and should sound as good day one as it will years after and probably would be considered spark arresting too, I don't know for sure.
Old May 12, 2013 | 12:36 AM
RaceGass's Avatar
The smallest I. D. Noise restricting insert that 2bros offers reduces the sound output at idle significantly but not close to the klx300 system. Upper revs sound output is a lot quieter also, but still has bark. Like suggested if noise is a concern the klx300 system w/ Powerbomb header would be a good combo..
wdg
Jul 31, 2008 01:33 PM
Dirt days
Jul 13, 2008 03:22 AM
preemo_21
Feb 22, 2008 04:17 AM
Lunchbox8922
Ninja 500R
Sep 20, 2007 02:28 AM
Snal
Mar 4, 2007 08:53 AM
