new owner
Old Jun 2, 2008 | 05:53 AM
tremor38's Avatar
Default RE: new owner
+1
Also, open-up the air box by at least removing the snorkel. More air in + more air out + rejet = more power. Just be sure to rejet BEFORE you open the air box.
ORIGINAL: KLXer
Your pipe is fine--did you rejet? You need to if you didn't. I dont careif 3 mothers says you dont.
Old Jun 2, 2008 | 03:33 PM
djmerullo's Avatar
Tremor knows whats best. I did exactly what he said and I feel a big differance. Instead of doing the front sprocket I just changed the rear. I think it made a huge differance. I put a 47 tooth on and I feel it pull in all the right gears. When it comes to changing tires go with the pirelli mt21 and go with a TrakmasterII 110/100-18 rear. Its taller than the normal tire but it fits fine on the 06.. Rubs on the little mud flap in the front but no biggy just push it out the way
Old Jun 2, 2008 | 05:50 PM
09KLXowner's Avatar
Banned
ORIGINAL: djmerullo
putting a tire on that big is good for grip, but because it will suck so much of your power you won't need the grip much anymore, also it won't handle nearly as good. Also, a 47 tooth rear will kill any on-road ridability asthe bikewill always be screaming.
just remember that each tooth added up front is equal to three in the rear. so 13/42 is the same as 14/45. stock gearing is best for on-road riders.
optimuzs
Sep 14, 2012 04:19 PM
barny
Jul 31, 2010 03:37 AM
buff36
May 27, 2009 03:36 AM
mwerneke
Jun 20, 2008 04:19 AM
Bonafide
Apr 16, 2006 08:21 PM
