needle jet
Old Jan 29, 2009 | 03:10 AM
hatto's Avatar
Default needle jet
Hi All,
It's been ages since I have been here, there just dosen't seem to be enough hours in the day.
Anyway, I have been tinkering with the bill blue carby and have been searching up jetting.
Is it the jet needle that I should be changing or is it the needle jet. On the link below-number 6 or number 37. I am going to get the Q-o to try.
I have only ever changed the pilot and main, should I be doing anything else.
thanks in advance
Hatto
Sorry - hears the link http://www.motorcyclecarbs.com/mikun...es/TMframe.htm
Old Jan 29, 2009 | 03:43 AM
ddt1972's Avatar
link?
Old Jan 29, 2009 | 04:08 AM
hatto's Avatar
Originally Posted by ddt1972
link?
Sorry, I am a dumbarse
Old Jan 29, 2009 | 12:18 PM
mustang's Avatar
In that diagram, the needle jet is #37. The stock size is a P-8. When I was running a Bill Blue TM34, I bumped mine up 1 notch to a Q-0.
Old Jan 30, 2009 | 02:25 AM
b_joannblue's Avatar
the needle jet has been drilled out to a Q-O already that is one of the mods that I do to the carb.
What is the problem you are having? I will try to help you with it.
Bill
Old Jan 30, 2009 | 08:03 PM
hatto's Avatar
Bill
Hi Bill,
No real problems, I just wasn't sure if i have it dialled in completely and thought i would see the difference, but if it's already done than good.
I have a slight problem with surging at Idle (rich or lean???) and need to change idle once warm otherwise it hangs on when idleing down steep hills slow
I am changing throttle and cable this week, so that may fix because they are worn
cheers and thanks for replies everyone
hatto
stro
Apr 12, 2012 10:05 PM
KINGVEGAS
Ninja 500R
18
Nov 25, 2007 02:11 AM
YYY.GUY
Aug 4, 2007 03:49 AM
kawicat
Apr 26, 2007 04:36 AM
Bad Bear
Sep 4, 2006 10:27 PM
