How do you adjust the Mikuni Jet Needle?
Old Aug 3, 2007 | 09:33 PM
YYY.GUY's Avatar
Default How do you adjust the Mikuni Jet Needle?
Ok, here's my stupid question of the day:
Can the needle [8] be adjust up/down by taking the top cover [2] off while its on the bike, or do you have to take the wholeair funnel[12] off (which means you have to drop the float bowl [31] in order to remove the A/P nozzle [36] first?
I know you eventually have to undo the 2 screws [4] above the needle , but can it all be done from the top, which means taking out the throttle lever bolt [58] and swinging the throttle lever [56] up out of the way? Or can it still be done from the top, but you have to remove the whole shift assembly shaft [53] ("shift shaft"?) because the throttle lever won't move far enough out of the way?
Man, working on these little suckerscan be complicated!
Thanks!
Mike
Old Aug 3, 2007 | 09:51 PM
kgwld1's Avatar
Default RE: How do you adjust the Mikuni Jet Needle?
I'll I have to do is pull the top cover and one screw and pull the needle and adjust the clip, It took me longer to type this then do it.
Old Aug 3, 2007 | 11:14 PM
YYY.GUY's Avatar
ORIGINAL: kgwld1
Cool! Which screw?
Old Aug 3, 2007 | 11:28 PM
kgwld1's Avatar
Ithink its 4 and 5 swings out of the way.
Old Aug 4, 2007 | 03:49 AM
YYY.GUY's Avatar
Excellent, thanks!
stro
Apr 12, 2012 10:05 PM
Davebert
Mar 1, 2008 01:24 AM
KINGVEGAS
Ninja 500R
18
Nov 25, 2007 02:11 AM
kawicat
Apr 26, 2007 04:36 AM
Bad Bear
Sep 4, 2006 10:27 PM
