Need Help!
Old Dec 12, 2014 | 10:14 PM
  #61
^ Maximum, that there is good advice!
Old Dec 12, 2014 | 10:58 PM
  #62
kotchman33's Avatar
The exhaust and air intake are not to blame.
Carb might be
Will try the spark plug too soon
The mystery continues...
Old Dec 12, 2014 | 11:04 PM
  #63
Brieninsac's Avatar
Just thinking out loud here, but have you checked the fuel lines?
Old Dec 12, 2014 | 11:09 PM
  #64
kotchman33's Avatar
Does this make sense, I think the throttle slide is not being pushed up by the needle. When I push on the throttle slide it goes up, but when pushing on the needle only there seems to be only the spring moving
Old Dec 12, 2014 | 11:10 PM
  #65
kotchman33's Avatar
Fuel lines were checked
Old Dec 13, 2014 | 12:32 AM
  #66
kotchman33's Avatar
I hope I don't sound like an idiot saying this...
Old Dec 13, 2014 | 12:40 AM
  #67
MattyTracks's Avatar
The needle doesn't push the slide up, the diaphragm on top of the carb does. If you have the carb out you should be able to manually lift the slide, the needle will raise out of the main jet with the slide. While manually opening the slide you should hear the diaphragm pumping air. I'd remove the top cover and inspect the whole slide/diaphragm assembly.
Old Dec 13, 2014 | 12:44 AM
  #68
kotchman33's Avatar
Did that and everything was fine. Tomorrow morning I will try it out and hope for the best
Old Dec 13, 2014 | 02:33 AM
  #69
durielk's Avatar
Clean your jets before installing in the moto.
Old Dec 13, 2014 | 02:42 AM
  #70
kotchman33's Avatar
Update: took out the spark plug to find a crap ton of sand surrounding it. Cleaning now and will buy spark plug in the morning
