NEED A COIL HELP
Old Jun 1, 2008 | 11:42 PM
doitinthewoods's Avatar
Default NEED A COIL HELP
Kawi say's it's on backorder not sure for how long thing is they have my bike where can I find??? also still looking for an OEM headlight shroud will pay
Old Jun 1, 2008 | 11:53 PM
Default RE: NEED A COIL HELP
I have one. I had an electrical problem a while back and swapped out the coil to eliminate it, but it was not the problem. The problem turned out to be my CDI. The coil I have is the used coil because once I swapped out the old for the new, I just left the new installed even thought that didn't fix the problem and I didn't bother to put the old one back on. So I'm 97.3% sure it's good. The only way it wouldn't be is if my coil AND my CDI both went bad simultaneously.
PM me if you are interested.
Old Jun 1, 2008 | 11:54 PM
I should mention, mine is the '06 part. I don't know if it changed for later model years. You should confirm that before getting mine.
BARLOWSRUN
Oct 7, 2007 03:30 AM
95zx6rGuy
Jun 8, 2007 01:12 PM
greenhornet
Mar 21, 2007 10:07 AM
kappa6m3
Oct 16, 2006 08:28 AM
kdogg123
Jul 31, 2006 07:18 AM
