My Rack Has Arrived -- Nomadic Racks
Old Jun 15, 2009 | 01:28 PM
  #51
EdForsythe's Avatar
Default Fender Mounting Bolts
Hi Justin,
I have a lime green 250S with your rack installed and it looks like original equipment. It fit perfectly. I wanted to retain my tool kit but I didn't want it to occupy needed rack space so I only used the rear connection holes in the pack and let the front "float".
I have one major problem. The socket head bolts that connect the rack to the fender protrude significantly above the rack and will rapidly wear through anything bun-geed over them i.e laptop bag, grocery bag/s etc. I replaced them with pan head bolts which will wear less but nevertheless destroy my laptop bag. I'm thinking of taking the rack to a machine shop and having the holes countersunk so that i may use flattop bolts Another solution may be to grind off enough material so that the pan head bolts will be flush with the rack top. Do you have any suggestions? I'd really appreciate some help.
Ed F.
Old Jun 23, 2009 | 09:46 PM
  #52
pking911's Avatar
Nomadic, do you have any more racks available?
Old Jun 24, 2009 | 01:53 AM
  #53
swilson's Avatar
He seems to be selling them through Ebay. He doesn't have any listed at the moment. Here is a link... http://motors.shop.ebay.com/merchant...rmrsZ1QQ_fromZ
Old Jun 24, 2009 | 04:00 PM
  #54
pking911's Avatar
yup, I searched eBay already before I posted. Thanks for the link. I am going to add him as a favorite seller.
Old Jun 25, 2009 | 12:22 AM
  #55
WestOzKLX's Avatar
Originally Posted by EdForsythe
Hi Justin,
Ed F.
Fit a flat plastic base to the top of the rack. A lot of people us one of those cheap plastic chopping boards, cut to size.
Old Jun 25, 2009 | 02:01 AM
  #56
Nomadic Cycle Racks's Avatar
The racks are up for grabs again fellas!
Old Jun 25, 2009 | 07:48 PM
  #57
luvnidaho's Avatar
Yahoo! Got mine -- I hope.
Old Jun 26, 2009 | 12:38 PM
  #58
uk_nick's Avatar
Fitted a Metal Mule box to my Nomadic rack.
Might not be to everyones taste, but it keeps my stuff secure and dry!
Old Jun 27, 2009 | 05:56 PM
  #59
EdForsythe's Avatar
Hi,
Good idea but I solved the problem by substituting Oval head SS bolts for the socket heads. Then I used my trusty Dremel to grind off about 1/16" from the rack. Now the bolt heads are flush or slightly below the rack surface. Looks great.
Ed F.
Old Jun 28, 2009 | 12:50 AM
  #60
rcraig's Avatar
+1 on grinding the rack down. It is a great rack, but this is a design flaw. Anything strapped to the rack will not sit flush or will have holes worn through it in short order.
I ordered one of the racks as soon as they were up for sale again; got it in one day! Went on the bike in about 5 minutes. Fits great, looks stock. I will be grinding down the protruding bolt holes shortly. Once that its done I have a two gallon gas container that fits the rack like it was made for it that will strap neatly into place.
Craig
