Is it my battery or a bad connection
Old Feb 2, 2010 | 10:40 AM
mudjunkie's Avatar
bummer....good luck.
Old Mar 27, 2014 | 03:45 PM
mmmbeefy's Avatar
Default Old Thread dredging
The same thing as original post has started happening to me over the last few weeks. It first died while running. It leaned out and then died, I chalked it up to running out of fuel.
I switched to reserve and it started right back up. I then noticed the clock reset and tripometers were at zero. Later when I stopped for gas it only took a gallon so I don't think I was actually out of fuel in the first place.
Twice in the last week now it has been tough to start and then during cranking I noticed the clock and tripometers had reset again. This morning I cranked for 3-4 minutes before it finally started. The battery is a few months old and has plenty of juice to crank.
OP - If you're still around did you ever find the problem? Or has this been addressed in another thread that I've not seen?
Old Mar 28, 2014 | 01:15 PM
Nikolaj Lykke's Avatar
I have the exact same problem as OP and mmmbeefy. 2009 KLX250. Clock and tripmeters reset sometimes when I am trying to start it. Its like there isn't enough power and the starter motor also sounds like its struggling. Then the display flickers and resets.
Im really at a loss. Any ideas?
Old Apr 1, 2014 | 11:05 PM
mmmbeefy's Avatar
After a few more days it started acting like a low battery - I charged the battery and it hasn't done it since. I suppose the clock and tripometer reset because of low power even though the starter was cranking away.
Shrug. I suppose It's time to learn to be an electrician and see if the battery is charging or not.
On a side note, last night I tried the rectifier grounding mod, but the stumble is still there (and yes, I grounded the rectifier side of the wire, not the goes-to-infinity side).
Ironhead
May 18, 2010 04:43 AM
Nobrakes
Jul 29, 2008 10:54 PM
EMS_0525
Jul 26, 2008 11:28 AM
chris72a
Jul 20, 2008 01:15 AM
longinforabike:D
Ninja 500R
Jul 16, 2008 04:44 AM
