mpg seams a little low for stock...
Old Sep 3, 2008 | 06:28 PM
punkenduro09's Avatar
Default mpg seams a little low for stock...
after calculating my mpg from the ocotillo ride i did a few days ago, it seams my mileage was kinda low. i came out with 65, 65, 60 (off-road here so seams right) and 59? i was doing about 65 most of the time with short burst to 70, is it the higher rpm riding that does it? its just werid cus when i first got it, road basicly the same roads, the same speed with my dad and got nearly 80 mpg. bikes stock 09 for those wondering.
Old Sep 3, 2008 | 06:32 PM
Hmmmm when i got mine i was only averaging around 70 but now im gettin like 50-60 depending on how I ride,, But I also have a bigger jet so I dont know..
Check your airfilter see if anything got in there clogging it up
and also stay away from economy gas.. stay with franchise,, shell,bp,exxon.ammco ,ext.... Like I said before Economy gas=shi*tty gas this day in age,, Water'd down gas will throw it off also
Old Sep 3, 2008 | 06:46 PM
je2000's Avatar
What octane?
I try to keep the rpm's on the highway at 7k max. That should be 70mph indicated.
60-65mph indicated you'll probably see a lot better fuel economy.
I'm pretty sure all the highway mpg ratings come from when the vehicle is run 55mph. And for bikes it's usually a tiny Asian dude at 145lbs.
That is complete speculation about the asian dude, but it's probably somewhat true.
Old Sep 3, 2008 | 06:55 PM
f1rocco's Avatar
My 09 stock averages
Under 4k rpmz
70mpg +
Over 5 and under 7k rpmz..
64-66mpg
Mostly 55mph and over 6-9k rpm range
58-62 mpg
WOT and a full tank...My guess
53mpg
Go jet kit and you can subtract 10mpg off of each of these numbers if not more.....My guess is that the USA bikes have a different timing set up for emissions....Alot of people post up some great mpg numbers....But these numbers above reflect my 200lb self over the last 3 months and 2500 miles on my 09 in New York State..
Rocco
Old Sep 3, 2008 | 07:51 PM
JasonFMX's Avatar
Yeah, I'm getting like 63mpg riding anywhere from 2500rpm - approx 7000rpm on streets and trails. True dual sporting variances.
________
Ipad Accessories
sinkoman
Sep 12, 2007 11:55 PM
bryantjt
Aug 4, 2007 04:00 PM
EMS_0525
Joke section!
Mar 1, 2007 02:10 AM
KAWASAKIspeed
May 10, 2006 08:21 PM
jds636
Oct 17, 2005 11:46 PM
