Moto-Pro Fork Valve Install Questions
Old Jan 22, 2008 | 12:15 AM
mooredan's Avatar
Default RE: Moto-Pro Fork Valve Install Questions
ORIGINAL: mooredan
Spoke to John at Moto-Pro today and he got me on the right track.
This photo is almost correct. The correction is that instead of 2 base spacers, there needs to be 3 base spacers.
The number of base spacers may be 2 or 3, this is dependent upon the number and thickness of the compression shims used. The number and thickness of compression shims is based upon weight, ridiing style, etc...
The key is to ensure that the spring retaining nut clamps down on the stack while not pinching the check plate. The check plate needs to be able to move up and down along the collar built into the spring retaining nut.
(With the exception of the base, none of the original valve stack is used).
David R
May 27, 2011 03:59 AM
punkenduro09
Mar 29, 2009 03:38 AM
mooredan
Jan 28, 2008 06:26 PM
Marty
Nov 29, 2006 10:32 PM
