Mixture Screw-driver
Old Sep 3, 2006 | 07:19 AM
YYY.GUY's Avatar
Default RE: Mixture Screw-driver
Very cool!
I was thinking that the mixture screw was something that you could set without the engine running, so any small screwdriver that fits would work. If that's the case, maybe one of those tiny eyeglass repair kit screwdrivers might work:
Or possibly a double ended, hex-drive bit is long enough to twist with your fingertips.
(Personally, I think pretty much anything that lets you avoid pulling the carb is a good solution!!! )
Mike
Old Sep 3, 2006 | 09:24 PM
Waxface's Avatar
Why dont you just get another Idle thumbwheel set up and grind the threaded end into a flat head tip? Maybe even find away to mount it so you can adjust it anytime easily? Just a thought.
LordVngr
Sep 16, 2006 03:49 AM
gfoster
Sep 2, 2006 09:36 PM
Bad Bear
Aug 28, 2006 11:28 PM
krntl13
Jul 23, 2006 02:58 AM
ZX_9r
May 13, 2006 06:46 PM
