Mikuni TM33/34 jetting
Old Mar 16, 2019 | 09:00 PM
Mick-f's Avatar
Default Mikuni TM33/34 jetting
2009 Kawasaki 250s, with Bill Blue 351 kit. This would rev normally with the stock carb. With the Mikuni it Boggs down at around 8k rpm, under acceleration. Do I need a larger main air? It has the one Bill put in for sea level running.
I have never worked on this particular carb before, does it have to be removed to change the jet?
Thanks, Mick
Old Mar 21, 2019 | 08:50 PM
Doc's Avatar
Doc
Thanks, Mick
Mick I have a 2006 with a BB 351 and TM33/34 carb from Bill with a full muzzy exhaust. I run a 40 pilot and a 145 main with no issues. I think the carb came with a 37.5 pilot and a 140 main if I remember correctly. I also have the KDX snorkle on the air box. Best to remove it to work on it.
Hope that helps.
File Type: pdf
Old Apr 10, 2019 | 10:55 AM
Mick-f's Avatar
Thanks. I removed the Airbox cover and the problem went away. Hopefully today I can go out and get some dirt on it, temps in the 50's
Mick
Old Apr 13, 2019 | 04:45 PM
durielk's Avatar
If it clears up without the cover, IMO, your running too rich.
Old Apr 15, 2019 | 03:45 AM
Ram9cc's Avatar
Thanks, Mick
Hi Mick.
i have a kit at sea level - Oakland. I have the lid on. The carb came way rich. I think due to humidity. I installed a wideband sensor so I could read the air fuel mixture.
I am currently running a 130 Main and a 35 pilot. The bike is running between 0.7 and .9 now (1.0 being lamda (14.7:1) .
i’m planning to go down a size in both pilot and main next weekend an redo my datalog runs for 1/4, 1/2, WOT.
I ran a 135 main jet and a 35 pilot with no air box lid and it was right around 1.05 - .85 which felt pretty good and made a racket lol.
Conculusions : defiantly the 140/40 setting from bill was very rich for my weather - I could see it working with a full exhaust and a k&n and no air box lid - but even then I think it would become over rich in the higher temps..
where red are you located ? What humidity? What temps ?
bandit88
Jul 8, 2015 12:52 AM
postoak2
Mar 14, 2013 10:22 PM
FM_Thumper
Jul 8, 2012 08:35 PM
Radius
Sep 24, 2009 04:51 AM
lcpl0331
Feb 3, 2008 01:32 PM
