Mikuni TM 36-68 BASELINE NEEDED
Old Oct 11, 2011 | 02:01 PM
GaryC's Avatar
Default Mikuni TM 36-68 BASELINE NEEDED
Guys, i just bought the 36-68 pumper and need a baseline for jetting.
I am at sea level, have a Q4 quiet pipe slip on, and air box cover removed.
Let me know if you have (or had) a similar condition and what you have (had) for jetting please.
Old Oct 11, 2011 | 03:12 PM
David R's Avatar
Pilot 17.5
main 130
P6 Needle jet
Optional Needle, I don't remember the #.
I was getting almost 60 mpg with this setup and a 351.
I traded in the SF for a Versys, so somebody gets one hellofa bike.
David
Old Oct 11, 2011 | 04:50 PM
GaryC's Avatar
Congrats on the new ride.
How do you like it? i just went at lunch time and sat on a Versy, and a KLR.
I can't make up my mind between the 2 which i like better.
Old Oct 11, 2011 | 04:52 PM
GaryC:
I'd be interested to hear your mileage results, as I get the impression you ride more trails than DavidR. I read so many reports on other sites where the pumper carbs really decrease mileage, but DavidR and a few others here have reported fairly good mileage. Mileage is critical to me for some of the riding I do with over 200 miles between pump stations.
Old Oct 11, 2011 | 05:13 PM
GaryC's Avatar
I am hoping to get more than with the stock carb after it is set up properly.
I was only getting 35 to 40mpg withthe stockcarb after rejet in the trails but that was on open sand roads and 2 track where i am abusing the throttle most times.
Im hoping that i don't get a really big hit with the pumper like is on the CRF i used to own. The CV is nice and mellow with power delivery but,,, too mellow for me.
Old Oct 11, 2011 | 05:55 PM
jhoffy22's Avatar
At Sea Level, 55 degrees F - my final settings:
MAIN JET 127.5
NEEDLE JET 585-P-6
JET NEEDLE 9EBY01-51 (position 4) - 4th from the top
PILOT JET 22.5
PILOT AIR JET 1.0
MIXTURE SCREW 2 TURNS OUT
PUMPER NOZZLE SPLASHING OFF NEEDLE
PUMPER STARTS AT 1/8 THROTTLE AND STOPS AT 3/4
I had to richen the pilot/idle band, lean out the midrange and WOT
17.5 pilot jet was not rich enough to take the lean hesetation out of the 1/4 throttle band, so the 0.7 (smaller) pilot air jet did the trick, as well as raising the needle two notches
I highly recommend this carb!
-Tiger
Old Oct 11, 2011 | 05:59 PM
GaryC's Avatar
MAIN JET 127.5
NEEDLE JET 585-P-6
PILOT JET 22.5
PILOT AIR JET 1.0
-Tiger
I think TIGER has his snorkel in, my air box is open (lid OFF), that will make a difference.
But thanks for the imput JHoffy!!
Old Oct 12, 2011 | 05:18 AM
T_i_G_e_R's Avatar
Hi Gary, I have used every setting possible.. what is your bore size
Old Oct 12, 2011 | 05:22 AM
T_i_G_e_R's Avatar
for a 351 i recommend taking the carb apart and putting a p6 needle jet with 127.5 main jet and 20 idle jet..
once you have the carb in you can switch in and out the needle easily.. 50 needle is a tad leaner than the 51 needle. at sea level, the 50 needle should be fine.. should scream with these basic settings.
Radius
Sep 24, 2009 04:51 AM
zx7rydr
Nov 30, 2008 01:21 PM
Dragone#19
Ninja ZX-10R
Jul 21, 2007 01:17 AM
klxstiffler
Apr 25, 2006 02:26 PM
bryanklx250s
Jan 20, 2006 01:15 AM
