MCM & ACR Spring
Old Sep 16, 2021 | 03:13 AM
ForestThump's Avatar
Default MCM & ACR Spring
For those who are knowledgeable, it seems that some (most?) folks who’ve done the MCM mod on these bikes just pull the spring from the ACR rather than have a machine shop reposition it - since ACR is pretty much of no use with electric start.
Having not been in the engine yet to see it for myself, my question: can the spring be reinstalled at a later time if needed? Like, say, if I decide to install a kick start some day? Or once it’s been pulled, is it out for good?
Old Sep 16, 2021 | 04:21 AM
Brewster's Avatar
The spring is easily removed or put back on. But why remove it in the first place? You may be in a situation where you want to bump start the bike.......like low battery charge.
Ride on
Brewster
Old Sep 16, 2021 | 04:32 PM
Klxster's Avatar
Brewster, you remove the spring so that you CAN bump start, electric start, etc, (when you are running the MCM)..
Replacing the spring with the MCM still on the engine causes non starting especially when hot..
Repositioning the KACR correctly, for use with the MCM, allows normal KACR operation and starting ops..
Old Sep 16, 2021 | 06:23 PM
That and the electric start doesn't need a compression release in the first place on the 250. That is a left over from the kick start 300s.
FabriKLX
KLX300R
Apr 5, 2021 03:58 PM
Dirtrider4207
Jul 1, 2017 12:13 AM
frogandtoad
Dec 7, 2014 02:47 AM
Senator24
Mar 5, 2009 02:59 AM
LeftyS7
Nov 11, 2006 05:52 AM
