Loose head bolts?
Old Jun 22, 2009 | 11:30 AM
leisman7's Avatar
Default Loose head bolts?
What are the signs that your head bolts may be loose?
Old Jun 22, 2009 | 11:48 AM
neilaction's Avatar
Depends how loose.
If its just not torqued down enough, there may be no obvious signs until you blow a head gasket.
Then you may have one or more of the following symptoms.
Water in your oil, low compression, won't run at all, consuming water.
Old Jun 22, 2009 | 11:55 AM
leisman7's Avatar
Im asking because recently put on the 351 big bore kit. Ran it for 30 minutes and retorqued the bolts. One of the bolts sliped to 30 while i was torqing it down they are supposed to be at 35. I gave the bolt another try, It did not slip again and i was able to get it back to 35. Then i steped it up to 37(recomended by someone) and thats where i kept it. Im wondering if the thread got messed up and something might get fubar.
Old Jun 22, 2009 | 01:21 PM
neilaction's Avatar
Its probably OK.
I guess your choice is to pull the bolt in question and check the thread.
I would be tempted to leave it and keep an eye on water level and oil condition.
First sign of milky oil or dropping water level, pull the head and check it out.
Could be a heli coil job.
Old Jun 22, 2009 | 01:35 PM
leisman7's Avatar
Hey thanks alot man
Old Jun 22, 2009 | 01:52 PM
neilaction's Avatar
Hey thanks alot man
IMO worst case is a blown head gasket.
As long as your onto it straight away, there shouldn't be any more serious damage.
But, the moment you notice water loss, fix it.
Keeping on riding and topping up the water is flirting with something more serious.
Old Jun 22, 2009 | 10:16 PM
leisman7's Avatar
How do i check water levels?
Old Jun 22, 2009 | 11:51 PM
lcpl0331's Avatar
look in your radiator or coolant reserve tank. Your oil will get milky too. Look in the site window. IF you see any white or tan milky **** in there you have a problem.
Old Jun 23, 2009 | 02:36 AM
leisman7's Avatar
Thanks brother
IDRIDR
Dec 8, 2011 09:47 PM
preemo_21
Ninja ZX-7R
Apr 22, 2008 03:11 AM
preemo_21
Apr 21, 2008 12:25 PM
gerrynolan
Dec 23, 2007 02:35 AM
gerrynolan
Aug 5, 2007 06:18 AM
