A Little Help with Jetting?
Old Sep 8, 2015 | 02:37 AM
  #41
Klxster's Avatar
Let me know if throttle response improves (But NOT a snap to WOT from 2k..) when you've reset the fuel screw to just the other side of lean idle drop and a idle of 1300..
Old Sep 8, 2015 | 03:00 AM
  #42
pwjm's Avatar
Originally Posted by Ruggybuggy
Thanks for the dial a jet info. Definitely something to consider.
Yes my doggy feel is below 2500 rpm. If I'm moving along slowly with the clutch out, RPMs under 2000, and full throttle the bike I get a slight "nothing" for a slight second then the power build the closer I get to the 4000 mark. After that now issues. That was one reason I asked about what happens when you drill the slide. Does it delay the movement of the slide or allow the slide.to move quicker. I would have thought drilling would have reduced the vacuum effect on the slide and make it work slower.
Needle (and slide) don't come into play much at all until 3500 rpm. Sounds exactly like a pilot jet issue from what I've read.
Old Sep 8, 2015 | 03:27 AM
  #43
Ruggybuggy's Avatar
I have the exhaust cam out tonight and going press off the KACR at work tomorrow and through it in the trash. When I get it back together tomorrow I'll report back.
dubie56
May 12, 2011 03:22 PM
redpillar
Dec 2, 2010 04:30 PM
EMS_0525
Aug 25, 2007 10:37 AM
EMS_0525
Joke section!
Mar 1, 2007 02:10 AM
KAWASAKIspeed
May 10, 2006 08:21 PM
