LED Turnsignal Resistor/Relay (09' gen) HELP
Old Nov 15, 2010 | 12:18 AM
thejackcutts's Avatar
Default LED Turnsignal Resistor/Relay (09' gen) HELP
Hi Eryone!
So, as most of you know, when you take off your stock turn signals or put the LED ones on, the lights flash faster. This is due to the amount of electricity drawn to the lights.
Well i have the Edge 2 Tailight with the circut board mod, and 2 LED turnsignals on the front.
i boaght a Turnsignal Resistor and not i am stuck, i know that it has to be put in between where the turnsignals connect to the main but i cannot figure out where to put it exactly.
If any of you have done this, where did you put the resistor?
i have an 09' im not sure if that is a factor or not...
THANKS VERY MUCH GUYS!!!!!
Old Nov 15, 2010 | 01:46 AM
linkin5's Avatar
If I remember right you just splice it in the 2 wires that go to the signal, put it where you can zip tie it out of sight.
Old Nov 16, 2010 | 01:57 PM
Robert24's Avatar
Hi there,
All you have to do is purchase a led flasher relay part# 44891 grote.
It is a 3 wire relay so, 2 wire from relay and ground the white wire from the new relay .. no heat from those resistor and less charge on your system.
canehdian_guy
Apr 15, 2015 02:26 AM
mmurray70
Feb 29, 2012 03:15 PM
2k1w=no$
Mar 20, 2010 04:58 PM
dacoontz
Feb 16, 2008 10:06 PM
wcdetjen
Sep 23, 2006 10:50 PM
