Lastest Mods
Old Oct 23, 2007 | 05:26 AM
tremor38's Avatar
Default RE: Lastest Mods
ORIGINAL: DC4500
Well it has taken some time to finish but here is the new rear fender. I use the Maier MX and Baja Designs LED taillight/brakelight which is so much better than the Acerbis that only worked when it wanted to. New LED blinkers were added as well. I never used the rack so I won't miss it.
That compliments your pipe nicely.
Old Oct 23, 2007 | 07:45 AM
MaverickAus's Avatar
Old Oct 23, 2007 | 01:48 PM
DC4500's Avatar
That looks like it but I'm not sure why it says Yamaha-Honda. I used P/N 600709 from Baja Designs. It functions as a taillight, brakelight, and license plate light.
Old Oct 23, 2007 | 01:52 PM
DC4500's Avatar
There were no resistors provided (other that what might be inherent to the blinkers themselves). Both front and rear blink at a faster rate than stock but I don't see any harm in that. Is there?
Old Oct 23, 2007 | 04:32 PM
bryantjt's Avatar
ORIGINAL: 2k1w=no$
I have the same setup. The led taillight is actualy very bright. Nobrakes modded his light even further and put bigger led's in. For those interested, even with cutting the subframe the rear rack can also be used with this setup.
I'd love to see this setup with the rear rack!
Old Oct 23, 2007 | 05:03 PM
DC4500's Avatar
Here's the deal. As 2k1w=no$ mentioned, the rack can be used with this setup. In my case however, I didn't really put the forethought into the mod that I should have. The result is a tottaly frankenstien'ein hacksaw job on the subframe in order to use the high loop piece from the subframe and havethe fenderflow with the lines ofthe rest of the bike. This mod done with a little more planning/fabrication skill would allow you to install the rack but I'm not sure how well the fender would flow? At any rate, I don't think it's an option for me given the method I used. I'm just saying plan your cuts better than I did.
Lawnica1
Aug 14, 2010 06:37 AM
gotrice
Nov 26, 2005 06:48 AM
bmoore
Ninja ZX-10R
Aug 28, 2005 12:23 AM
onewheel
Jun 13, 2005 06:01 PM
